Boas...
Tive oportunidade e la fiz um scan, para meu espanto apareceu me mais erros para alem do airbag, mas opara já vamos analisar o airbag...
cá vai:
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 8L0 906 018 M
Component: 1.8L R4/5VT G 0002
Coding: 05710
Shop #: WSC 00000
1 Fault Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
Address 15 -------------------------------------------------------
Controller: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
2 Faults Found:
01217 - Side Airbag Igniter: Driver Side (N199)
32-10 - Resistance too High - Intermittent
01218 - Side Airbag Igniter: Passenger Side (N200)
Address 17 -------------------------------------------------------
Controller: 8N1 920 880 H
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 01144
Shop #: WSC 46200
XXXXXXXXXXXXXXXXX AUZ5Z0C2275062
3 Faults Found:
01315 - Transmission Control Module
49-00 - No Communications
01304 - Radio
01305 - Databus for Infotainment
37-00 - Faulty
Address 22 -------------------------------------------------------
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
1 Fault Found:
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04682
Shop #: WSC 01236
1 Fault Found:
00957 - Key 3
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45 -------------------------------------------------------
Controller: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00010
Shop #: WSC 01236
End -------------------------------------------------------
Agradeço toda a vossa colaboração...
Cumprimentos,
