Bancos eléctricos A4/B7
  • Thread starter Thread starter JM
1º fazes um scan geral, porque com o que foi desligado pela tentativa anterior devem existir alguns erros em memoria.
Depois posta aqui.
Aqui está o meu primeiro scan...
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 77933 146 84117
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
1 Fault Found
00532 - Supply Voltage B+
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Time Indication: 0
Freeze Frame:
Hex Value: 0x1200
Hex Value: 0x5302
Hex Value: 0x00FF
Hex Value: 0xFFA1
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2728
Coding: 00000
Shop #: WSC 06325
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 11021
Shop #: WSC 65536
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M0014RXA
Coding: 0033622
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04042
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0004041
Shop #: WSC 05572 843 13298
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H52 0650
Revision: 07S Serial number: AUZBZ7D0400356
Coding: 0309217
Shop #: WSC 00000 785 00200
2 Faults Found
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:07
Freeze Frame:
Voltage: 12.70 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:02
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BS
Component: Komfortgerát TA7 3332
Coding: 23408
Shop #: WSC 12397
Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Part No: 8E0 941 329
Component: AFS-Modul links H01 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309217
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:07
Freeze Frame:
Voltage: 12.70 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 167
Time Indication: 0
Date: 2009.03.30
Time: 09:09:02
Freeze Frame:
Voltage: 12.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
Component: Parkhilfe 8-Kan H06 0020
Revision: 00H06000 Serial number: 00067802130432
Coding: 0000114
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 M HW: 8P0 862 335 M
Component: FSE_255x BT H21 0200
Revision: 00000001 Serial number: 00000000434796
Coding: 0001811
Shop #: WSC 77933 150 84117
Os erros no endereço 03 - ABS e 37 - Navigation continuam mesmo depois de apagares os erros?
É que esses 2 erros têm tudo a ver com a bateria em "baixo", ou seja, com pouca voltagem.
Quantos anos tem?
Nunca limpei os erros, nem sei como se faz, e também não sei a idade da bateria. Comprei o carro usado (importado) e a bateria é a que veio com ele. Em todo o caso não sinto que a bateria esteja fraca, a menos que venha a sofrer de morte súbita (sem aviso prévio), algo que acontece muito com as baterias de hoje.
No VAG-COM, entras em cada modulo com erros, aparece o erro, clicas em clear errors, sais do modulo e voltas a entrar para ver se se mantêm.
Se a bateria é original, pelo ano do carro, a partir do 4º/5ª ano começa a ir á vida (começa a não carregar am andamento), dependendo da zona (fria, quente) e dos consumos, a vida da mesma diminui...
já limpei os erros e após novo scan já não aparecem. E sobre a cena das memórias do banco do condutor? Há algo que possa fazer com o vag-com?
Então se não aparecem, em principio está tudo OK.
Agora experimentas memorizar a tua posição normal do banco na memoria 1 por exemplo e verificas se funciona :-)
Não, não funciona, só memoriza os retrovisores os bancos não acerta.
Por acaso tenho a impressão que antes de andar a mexer com o vag-com os retrovisores também não memorizava, mas não tenho a certeza deste facto.
Sobre os bancos, será possível o módulo de conforto não saber da existência do banco do condutor ou vice-versa? e por esse facto não memorizar a posição.
ELFuracon disse:
Nos caso dos vidros electricos traseiros, estamos a falar no total de 4 fios (de cada porta) que devem ser ligados simplesmente a outros ja existentes e não é preciso ir ligar aos cabos das portas da frente.
1-Convenience CAN H
2-Convenience CAN L
Onde foste fazer esta ligação. No pilar A, junto ao pousa pés?
Foi fácil de ligar nos pinos OEM ou fizeste um bypass, um pouquito mais atrás, nesse fio.
JM disse:
Não, se está tudo ok, essa questão não se coloca.
A memorização dos bancos tem de ser feita com o carro parado.
É questão de seguires os passos do manual.
ELFuracon disse:
Bem, então é estranho, porque os comandos eléctricos dos dois bancos funcionam normalmente, consigo memorizar em qualquer uma das memórias posições distintas dos espelhos retrovisores, só o banco não fica com nem acerta a posição supostamente memorizada (nem se mexem quando carrego nos botões da memória). Ou há alguma ficha/fio que vai ao banco que não está ligada ou então não percebo, dado que no vag-com não aparece qualquer erro.
E a regulação electrica lombar funciona? nos comandos do botão redondo do banco?
Se não, verifica o termo-fusivel S45 E de 30 A.
