Viva carissimos!
Hoje com a ajuda do A4_Tuga encontramos isto num primeiro teste:
aturday,19,July,2014,14:26:31:32264
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Control Module Part Number: 8N0 906 018 A
Component and/or Version: 1.8l R4/5VT 0008
Software Coding: 05500
Work Shop Code: WSC 00066
VCID: 2F670D65ED066D1
6 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
17956 - Boost Pressure Regulation Valve (N75)
P1548 - 35-10 - Open Circuit - Intermittent
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
Readiness: 0000 0000
Limparam-se os erros, dei 3 voltas a apertar 1ª e 2ª...
E o resultado foi:
Data version: 20120401
Saturday,19,July,2014,14:33:01:32264
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Part No: 8N0 906 018 A
Component: 1.8l R4/5VT 0008
Coding: 05500
Shop #: WSC 00066
1 Fault Found:
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 J
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 01236
VCID: 387536391848AA9
No fault code found.
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043
Component: TT-KLIMAVOLLAUTOMAT D00
Coding: 00040
Shop #: WSC 01236
VCID: E7D725458576751
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 0004
Coding: 10102
Shop #: WSC 01236
VCID: F7F77505D5D6E51
Address 17: Instruments Labels: 8Nx-919-xxx-17.lbl
Part No: 8N1 919 880 E
Component: KOMBI+WEGFAHRS. M73 D29
Coding: 00144
Shop #: WSC 00066
VCID: 3F875D253D669D1
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0D5305111
Ident.-Nr. Wegfahrs.:AUZ5Z0D5305111
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267
Component: Zentralverrieg. D01
Coding: 04672
Shop #: WSC 01236
VCID: FEF96021FAECD49
3 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01617 - Please Check DTC Memory of Interior Monitoring
35-00 - -
Conclusão... Tudo indica que seja a sonda lambda ou tubos de vácuo...o a válvula N75!
Opiniões e experiências serão bem vindas!!
Obrigado A4_Tuga mais uma vez!
