mais exemplos de coisas que se podem fazer
Special software modifications VAG group.
VAG DSG Adjustments
Various modifications to the dsg controller:
Increase maximum torque.
Shorten switching.
Launch control.
Adjust speed for maximum upshift.
For a normal tuning of the engine these adjustments are not necessary, ask if you are interested in the possibilities and prices.
Various improvements Audi 2.0TDI PD BRE / BLB engine
Improvement software:
-cold / Warm-up phase, improved walking culture, less shake from idle to 1900tpm at part load.
-Hot / Hot improved engine running between 1100-1900tpm.
-Hot / Hot restart, better on after ~ 15 minutes of inactivity.
-EGR Shutdown.
-Lower / Silent / quiet idle, shaking / solved is uneven.
Sharpened 170hp 400Nm.
-Verbruiksreductie 2-5%.
This unique package of improvement costs 799, - and can be performed in whole or in part as required (price remains the same). Condition is that the engine is mechanically 100% and the astigmatism at idle max 1,5mg / s in MWB 13 (ask your dealer / specialist accompanied)
Warm Start adjustment 4-cylinder diesel.
After switching off the engine and wait 15-45 minutes, the car harder to the starter motor longer rotating strike for the engine, only half warm engine.
This enables us to rectify software, cost 150, - in combination with a chip tuning at greatly reduced rates, ask here.
EGR function off diesel.
The highly polluting engine EGR system, we can disable software to avoid problems, cost 150, - Combined with more torque at greatly reduced price, ask here.
EGR error code off 1.6TDI common rail
Error codes and function EGR off with error codes 7563 P046C EGR sensor 1 implausible signal / signal implausible and 7344 EGR sensor 2 P0408 signal too high / Signal too high.
This common fault with the 1.6TDI normally can only be remedied by replacing the EGR cooler, a repair of ~ 1250, -
Our solution causing the error code does not return a correct readiness for the MOT test, and no emergency running situations, in short hassle, costs 400, -
Improving idle 2.0TDI BLB A4 / A6
Some software versions running bad idle, it can be significantly improved by software, cost 475, - in combination with a more torque at greatly reduced rates, ask for.
Catalyst cold start operation is too small and bank1 or 2
Code 16805 P0421 Warm up catalyst efficiency below threshold bank 1 - MIL ON
Error Code and any fault indicator in many VAG models with petrol engine, official remedy catalyst (s) replace (very expensive) complete with front pipe, we can disable this error code, this has no effect on MOT, it is the warm-up catalyst, it is not measured during MOT tests.
The catalyst warm-up is mounted flush to the engine as a cat. only works at a relatively high temperature, just after the engine exhaust gases are the hottest. Furthermore, in the exhaust path, the exhaust along the much larger main catalyst, this ensures low emissions at operating temperature, which is measured during the MOT, this error is only applicable to the operation of the heating catalyst, the car is just as easy by the MOT test and continue to do that as long as the main catalyst is still working properly.
You save hundreds to thousands of dollars in some cases, cost 400, - 800, - depending on the type. Especially a very nice solution for W12 engines where we also secondary oxygen sensors (S1 S2 and S3 after the cat) can remove software, which occurs in-removing the engine! In combination with a chip tuning at greatly reduced rates, ask here.
Error Code air intake manifold 2.7 and 3.0TDI
Code 012 597 P3135 Intake manifold runner lower stopper Not Reached.
Code 008 224 P2020 Intake manifold flap position sensor bench 1/2 implausible signal.
Fault code and malfunction indicator air bypass valve bank 1 and / or 2 manifold lingers, the error code can normally be resolved only through an intake manifold or both to replace the mechanical valve sticking by wear and contamination. This valve is designed to EGR gases to better guide the engine at extremely low speeds, like the EGR valve control an environment where your engine without. This error code writing software saves 500-1200 euros, cost 500, - Combined with more torque at greatly reduced price, ask here.
Error Code throttle / choke 2.7 / 3.0TDI
This error code in the throttle, which is responsible for promoting the mixing of exhaust gases into the intake (EGR) returns an error by the malfunction indicator light (MIL).
This error can we uitprogrammeren, this error does not affect the driving behavior and save you replace these precious valve.
Error code 005 445 throttle valve controller malfunction.
Error Code secondary air injection system flow too low
Code 17831 P1423 Secondary Air Injection System Bank 1 Insufficient flow intermittently.
Gasoline engines equipped with a secondary air pump, this pumps extra air into the exhaust the first minute after cold start, along with other measures, this ensures lower emissions and faster heating of the catalyst tijdnes cold start, about the first minute.
If this pump is bad, a valve is stuck or another component of the system can lead to persistent faults with costly repairs, this error code uitprogrammeren without adverse side effects, costs 450 - W12 engines 750 - In conjunction with a chip tuning against greatly reduced rate, ask to speak here.
Particulate Filter / DPF problems
A well-known phenomenon in diesels over 100.000 ~ especially those not often reach operating temperature or for long periods; a clogged particulate filter, frequent regenerating, replacing the filter, high consumption, error codes on sensors. We can complete writing the particle filter which is no longer a problem occurs and consumption rather decreases (especially VW vans / couriers / VW Crafter / Transporter). You are responsible for ensuring that the filter is cleared, we can also make an offer if the software power off costs 750, - Combined with more torque at greatly reduced price, ask here.
After consulting with several environmental organizations, we have decided to immediately stop this adaptation.
Repair ABT tuning
Many 1.8T engines which have been tuned by ABT in the past after years of error codes on the checksum, initially only an error code:
16985 - Internal Control Module P0601 -35-00 memory check sum error.
Later, a fault LED and the final stage, the motor stops it. The cause is an internal error in the checksumberekening of codeersokkel who posted ABT. We can fix this error so you need to buy a new engine control unit and the tuning you can keep / transfer without this error, cost 400, -
Immobilizer disable engine control unit
Only for special motor-conversion, racing applications, etc. After consultation evidence ownership of the motor / ECU we can unlock the original immobilizer, cost 500. -
All the above adjustments are safe, without side effects and APK-resistant but omit the relevant theoretical initial Euro standard, these effects are at your own risk.
Selective error code off for dealers / garages:
In consultation we can disable specific error codes, persistent bugs that do not affect us to turn off the P-code.
This is what we always do in concert, sometimes it is unwise to do.
You can implement this in several rural dealers Hartog-tuning, or send the removed computer to us.
Please contact us for more information.
P-code
Description
16394
P0010
-A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction
16395
P0020
-A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction
16449
P0065
Air Assisted Injector Control Range / Performance
16450
P0066
Air Assisted Injector Control Low Input / Short to ground
16451
P0067
Air Assisted Injector Control Input / Short to B +
16485
P0101
Mass or Volume Air Flow Circ Range / Performance
16486
P0102
Mass or Volume Air Flow Circ Low Input
16487
P0103
Mass or Volume Air Flow Circ High Input
16489
P0105
Manifold Abs.Pressure or Bar.Pressure Voltage supply
16490
P0106
Manifold Abs.Pressure or Bar.Pressure Range / Performance
16491
P0107
Manifold Abs.Pressure or Bar.Pressure Low Input
16492
P0108
Manifold Abs.Pressure or Bar.Pressure High Input
16496
P0112
Intake Air Temp.Circ Low Input
16497
P0113
Intake Air Temp.Circ High Input
16500
P0116
Engine Coolant Temp.Circ Range / Performance
16501
P0117
Engine Coolant Temp.Circ Low Input
16502
P0118
Engine Coolant Temp.Circ High Input
16504
P0120
Throttle / Pedal Pos.Sensor Circ A Malfunction
16505
P0121
Throttle / Pedal Pos.Sensor A Circ Range / Performance
16506
P0122
Throttle / Pedal Pos.Sensor A Circ Low Input
16507
P0123
Throttle / Pedal Pos.Sensor A Circ High Input
16509
P0125
Insufficient Coolant Temp.for Closed Loop Fuel Control
16512
P0128
Coolant Thermostat / Valve Temperature below control range
16514
P0130
O2 Sensor Circ., Bank1-Sensor1 Malfunction
16515
P0131
O2 Sensor Circ., Bank1-Sensor1 Low Voltage
16516
P0132
O2 Sensor Circ., Bank1-Sensor1 High Voltage
16517
P0133
O2 Sensor Circ., Bank1-Sensor1 Slow Response
16518
P0134
O2 Sensor Circ., Bank1-Sensor1 No Activity Detected
16519
P0135
O2 Sensor Heater Circ., Bank1-Sensor1 Malfunction
16520
P0136
O2 Sensor Circ., Bank1-sensor2 Malfunction
16521
P0137
O2 Sensor Circ., Bank1-sensor2 Low Voltage
16522
P0138
O2 Sensor Circ., Bank1-sensor2 High Voltage
16523
P0139
O2 Sensor Circ., Bank1-sensor2 Slow Response
16524
P0140
O2 Sensor Circ., Bank1-sensor2 No Activity Detected
16525
P0141
O2 Sensor Heater Circ., Bank1-sensor2 Malfunction
16534
P0150
O2 Sensor Circ., Bank 2-Sensor1 Malfunction
16535
P0151
O2 Sensor Circ., Low Voltage Bank 2-Sensor1
16536
P0152
O2 Sensor Circ., High Voltage Bank 2-Sensor1
16537
P0153
O2 Sensor Circ., Bank 2-Sensor1 Slow Response
16538
P0154
O2 Sensor Circ., Bank 2-Sensor1 No Activity Detected
16539
P0155
O2 Sensor Heater Circ., Bank 2-Sensor1 Malfunction
16540
P0156
O2 Sensor Circ., Bank 2-sensor2 Malfunction
16541
P0157
O2 Sensor Circ., Low Voltage Bank 2-sensor2
16542
P0158
O2 Sensor Circ., High Voltage Bank 2-sensor2
16543
P0159
O2 Sensor Circ., Bank 2-sensor2 Slow Response
16544
P0160
O2 Sensor Circ., Bank 2-sensor2 No Activity Detected
16545
P0161
O2 Sensor Heater Circ., Bank 2-sensor2 Malfunction
16554
P0170
Fuel Trim, Bank1 Malfunction
16555
P0171
Fuel Trim, Bank1 System too Lean
16556
P0172
Fuel Trim, Bank1 System too Rich
16557
P0173
Fuel Trim, Bank 2 Malfunction
16558
P0174
Fuel Trim, Bank 2 System Too Lean
16559
P0175
Fuel Trim, Bank 2 System Too Rich
16566
P0182
Fuel temperature sender-G81 Short to ground
16567
P0183
Fuel temperature sender-G81 Interruption / Short to B +
16581
P0197
Engine Oil Temperature Circuit Low Input
16582
P0198
Engine Oil Temperature Circuit High Input
16585
P0201
Cyl.1, Injector Circuit Fault in electrical circuit
16586
P0202
Cyl.2, Injector Circuit Fault in electrical circuit
16587
P0203
Cyl.3, Injector Circuit Fault in electrical circuit
16588
P0204
Cyl.4, Injector Circuit Fault in electrical circuit
16589
P0205
Cyl.5 Injector Circuit Fault in electrical circuit
16590
P0206
Cyl.6 Injector Circuit Fault in electrical circuit
16591
P0207
Cyl.7 Injector Circuit Fault in electrical circuit
16592
P0208
Cyl.8 Injector Circuit Fault in electrical circuit
16599
P0215
Engine Shut-Off Solenoid Malfunction
16600
P0216
Injector / Injection Timing Control Malfunction
16603
P0219
Engine Overspeed Condition
16605
P0221
Throttle Pos. -B- Sensor Circuit Range / Performance
16606
P0222
Throttle Pos. -B- Sensor Circuit Low Input
16607
P0223
Throttle Pos. -B- Sensor Circuit High Input
16609
P0225
Throttle Pos. Sensor -C- Circuit Voltage supply
16610
P0226
Throttle Pos. -C- Sensor Circuit Range / Performance
16611
P0227
Throttle Pos. -C- Sensor Circuit Low Input
16612
P0228
Throttle Pos. Sensor -C- Circuit Hight Input
16614
P0230
Fuel Pump Primary Circuit Fault in electrical circuit
16618
P0234
Turbocharger Overboost Condition Control limit exceeded
16619
P0235
Turbocharger Boost Sensor (A) Circ Control Limit Not Reached
16620
P0236
Turbocharger Boost Sensor (A) Circ Range / Performance
16621
P0237
Turbocharger Boost Sensor (A) Circ Low Input
16622
P0238
Turbocharger Boost Sensor (A) Circ High Input
16627
P0243
Turbocharger Wastegate Solenoid (A) Open / Short Circuit to Ground
16629
P0245
Turbocharger Wastegate Solenoid (A) Low Input / Short to ground
16630
P0246
Turbocharger Wastegate Solenoid (A) High Input / Short to B +
16636
P0252
Injection Pump Metering Control (A) Range / Performance
16645
P0261
Cyl.1 Injector Circuit Low Input / Short to ground
16646
P0262
Cyl.1 Injector Circuit High Input / Short to B +
16648
P0264
Cyl.2 Injector Circuit Low Input / Short to ground
16649
P0265
Cyl.2 Injector Circuit High Input / Short to B +
16651
P0267
Cyl.3 Injector Circuit Low Input / Short to ground
16652
P0268
Cyl.3 Injector Circuit High Input / Short to B +
16654
P0270
Cyl.4 Injector Circuit Low Input / Short to ground
16655
P0271
Cyl.4 Injector Circuit High Input / Short to B +
16657
P0273
Cyl.5 Injector Circuit Low Input / Short to ground
16658
P0274
Cyl.5 Injector Circuit High Input / Short to B +
16660
P0276
Cyl.6 Injector Circuit Low Input / Short to ground
16661
P0277
Cyl.6 Injector Circuit High Input / Short to B +
16663
P0279
Cyl.7 Injector Circuit Low Input / Short to ground
16664
P0280
Cyl.7 Injector Circuit High Input / Short to B +
16666
P0282
Cyl.8 Injector Circuit Low Input / Short to ground
16667
P0283
Cyl.8 Injector Circuit High Input / Short to B +
16684
P0300
Random / Multiple Cylinder Misfire Detected
16685
P0301
Cyl.1 Misfire Detected
16686
P0302
Cyl.2 Misfire Detected
16687
P0303
Cyl.3 Misfire Detected
16688
P0304
Cyl.4 Misfire Detected
16689
P0305
Cyl.5 Misfire Detected
16690
P0306
Cyl.6 Misfire Detected
16691
P0307
Cyl.7 Misfire Detected
16692
P0308
Cyl.8 Misfire Detected
16697
P0313
Misfire Detected Low Fuel Level
16698
P0314
Single Cylinder Misfire
16705
P0321
Ign. / Distributor Eng.Speed Inp.Circ Range / Performance
16706
P0322
Ign. / Distributor Eng.Speed Inp.Circ No Signal
16709
P0325
Knock Sensor 1 Circuit Electrical Fault in Circuit
16710
P0326
Knock Sensor 1 Circuit Range / Performance
16711
P0327
Knock Sensor 1 Circ Low Input
16712
P0328
Knock Sensor 1 Circ High Input
16716
P0332
Knock Sensor 2 Circ Low Input
16717
P0333
Knock Sensor 2 Circ High Input
16719
P0335
Crankshaft Pos. Sensor (A) Circ Malfunction
16720
P0336
Crankshaft Pos. Sensor (A) Circ Range / Performance / Missing Tooth
16721
P0337
Crankshaft Pos.Sensor (A) Circ Low Input
16724
P0340
Camshaft Pos. Sensor (A) Circ Incorrect allocation
16725
P0341
Camshaft Pos.Sensor Circ Range / Performance
16726
P0342
Camshaft Pos.Sensor Circ Low Input
16727
P0343
Camshaft Pos.Sensor Circ High Input
16735
P0351
Ignition Coil (A) Cyl.1 Prim. / Sec. Circ Malfunction
16736
P0352
Ignition Coil (B) Cyl.2 Prim. / Sec. Circ Malfunction
16737
P0353
Ignition Coil (C) Cyl.3 Prim. / Sec. Circ Malfunction
16738
P0354
Ignition Coil (D) Cyl.4 Prim. / Sec. Circ Malfunction
16739
P0355
Ignition Coil (E) Cyl.5 Prim. / Sec. Circ Malfunction
16740
P0356
Ignition Coil (F) Cyl.6 Prim. / Sec. Circ Malfunction
16741
P0357
Ignition Coil (G) Cyl.7 Prim. / Sec. Circ Malfunction
16742
P0358
Ignition Coil (H) Cyl.8 Prim. / Sec. Circ Malfunction
16764
P0380
Glow Plug / Heater Circuit (A) Electrical Fault in Circuit
16784
P0400
Exhaust Gas Recirc.Flow Malfunction
16785
P0401
Exhaust Gas Recirc.Flow Insufficient Detected
16786
P0402
Exhaust Gas Recirc.Flow Excessive Detected
16787
P0403
Exhaust Gas RECIRC. Contr. Circ Malfunction
16788
P0404
Exhaust Gas RECIRC. Contr. Circ Range / Performance
16789
P0405
Exhaust Gas RECIRC. Sensor (A) Circ Low Input
16790
P0406
Exhaust Gas RECIRC. Sensor (A) Circ High Input
16791
P0407
Exhaust Gas RECIRC. Sensor (B) Circ Low Input
16792
P0408
Exhaust Gas RECIRC. Sensor (B) Circ High Input
16794
P0410
Sec.Air Inj.Sys Malfunction
16795
P0411
Sec.Air Inj.Sys. Incorrect Flow Detected
16796
P0412
Sec.Air Inj.Sys.Switching Valve Circ A Malfunction
16802
P0418
Sec. Air Inj. Sys. Relay (A) Contr. Circ Malfunction
16804
P0420
Catalyst System Efficiency Below Threshold Bank1
16806
P0422
Main Catalyst, Bank1 Below Threshold
16811
P0427
Catalyst Temperature Sensor, Bank 1 Low Input / Short to ground
16812
P0428
Catalyst Temperature Sensor, bank 1 High Input / Open / Short Circuit to B +
16816
P0432
Main Catalyst Efficiency Below Threshold Bank 2
16820
P0436
Catalyst Temperature Sensor, Bank 2 Range / Performance
16821
P0437
Catalyst Temperature Sensor, Bank 2 Low Input / Short to ground
16822
P0438
Catalyst Temperature Sensor, Bank 2 High Input / Open / Short Circuit to B +
16824
P0440
EVAP Emission Contr.Sys. Malfunction
16825
P0441
EVAP Emission Purge Flow Contr.Sys.Incorrect
16826
P0442
EVAP Emission Contr.Sys. (Small Leak) Leak Detected
16827
P0443
EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit
16836
P0452
EVAP Emission Contr.Sys.Press.Sensor Low Input
16837
P0453
EVAP Emission Contr.Sys.Press.Sensor High Input
16839
P0455
EVAP Emission Contr.Sys. (Gross Leak) Leak Detected
16845
P0461
Fuel Level Sensor Circ Range / Performance
16846
P0462
Fuel Level Sensor Circuit Low Input
16847
P0463
Fuel Level Sensor Circuit High Input
16885
P0501
Vehicle Speed Sensor Range / Performance
16887
P0503
Vehicle Speed Sensor Intermittent / Erratic / High Input
16889
P0505
Idle Control System Malfunction
16890
P0506
Idle Control System RPM Lower than Expected
16891
P0507
Idle Control System Higher than Expected
16894
P0510
Closed Throttle Pos.Switch Malfunction
16915
P0531
A / C Refrigerant Pressure Sensor Circuit Range / Performance
16916
P0532
A / C Refrigerant Pressure Sensor Circuit Low Input
16917
P0533
A / C Refrigerant Pressure Sensor Circuit High Input
16935
P0551
Power Steering Pressure Sensor Circuit Range / Performance
16944
P0560
Voltage System Malfunction
16946
P0562
System Voltage Low Voltage
16947
P0563
System Voltage High Voltage
16952
P0568
Cruise Control Set Signal Incorrect Signal
16955
P0571
Cruise / Brake Switch (A) Circ Malfunction
16984
P0600
Serial Comm. Link (Data Bus) Message Missing
16985
P0601
Contr.Module Internal Memory Check Sum Error
16986
P0602
Control Module Programming Error / Malfunction
16987
P0603
Internal Contr.Module (KAM) Error
16988
Designation p0604
Internal Contr.Module Random Access Memory (RAM) Error
16989
P0605
Internal Contr.Module ROM Test Error
16990
P0606
ECM / PCM Processor
17026
P0642
Knock Control Control Module Malfunction
17029
P0645
A / C Clutch Relay Control Circuit
17034
P0650
MIL Control Circuit Electrical Fault in Circuit
17038
P0654
Engine RPM Electrical Output Circuit Fault Circuit in
17040
P0656
Fuel Level Output Circuit Electrical Fault in Circuit
17084
P0700
Transm.Contr.System Malfunction
17086
P0702
Transm.Contr.System Electrical
17087
P0703
Torque Converter / Brake Switch B Circ Malfunction
17089
P0705
Transm.Range Sensor Circ. (PRNDL Inp.) Malfunction
17090
P0706
Transm.Range Sensor Circ Range / Performance
17091
P0707
Transm.Range Sensor Circ Low Input
17092
P0708
Transm.Range Sensor Circ High Input
17094
P0710
Transm.Fluid temperature sensor Circ. Malfunction
17095
P0711
Transm.Fluid temperature sensor Circ. Range / Performance
17096
P0712
Transm.Fluid temperature sensor Circ. Low Input
17097
P0713
Transm.Fluid temperature sensor Circ. High Input
17099
P0715
Input Turbine / Speed Sensor Circ. Malfunction
17100
P0716
Input Turbine / Speed Sensor Circ. Range / Performance
17101
P0717
Input Turbine / Speed Sensor Circ. No Signal
17105
P0721
Output Speed Sensor Circ Range / Performance
17106
P0722
Output Speed Sensor Circ No Signal
17109
P0725
Engine Speed Inp.Circ. Malfunction
17110
P0726
Engine Speed Inp.Circ. Range / Performance
17111
P0727
Engine Speed Inp.Circ. No Signal
17114
P0730
Incorrect Gear Ratio
17115
P0731
Gear 1 Incorrect Ratio
17116
P0732
Gear 2 Incorrect Ratio
17117
P0733
Gear 3 Incorrect Ratio
17118
P0734
Gear 4 Incorrect Ratio
17119
P0735
5 Incorrect Gear Ratio
17124
P0740
Torque Converter Clutch Circ Malfunction
17125
P0741
Torque Converter Clutch Circ Performance or Stuck Off
17132
P0748
Pressure Contr.Solenoid Electrical
17134
P0750
Shift Solenoid A Malfunction
17135
P0751
Shift Solenoid A Performance or Stuck Off
17136
P0752
Shift Solenoid A Stuck On
17137
P0753
Shift Solenoid A Electrical
17140
P0756
Shift Solenoid B Performance or Stuck Off
17141
P0757
Shift Solenoid B Stuck On
17142
P0758
Shift Solenoid B Electrical
17145
P0761
Shift Solenoid C Performance or Stuck Off
17146
P0762
Shift Solenoid C Stuck On
17147
P0763
Shift Solenoid C Electrical
17152
P0768
Shift Solenoid D Electrical
17157
P0773
Shift Solenoid E Electrical
17174
P0790
Normal / Circ Performance Switch Malfunction
17509
P1101
O2 Sensor Circ., Bank1-Sensor1Voltage Too Low / Air Leak
17510
P1102
O2 Sensor Heating Circ., Bank1-Sensor1 Short to B +
17511
P1103 does
O2 Sensor Heating Circ., Bank1-Sensor1 Output Too Low
17512
P1104
Bank1-sensor2 Voltage Too Low / Air Leak
17513
P1105
O2 Sensor Heating Circ., Bank1-sensor2 Short to B +
17514
P1106
O2 Sensor Circ., Bank 2-Sensor1 Voltage Too Low / Air Leak
17515
P1107
O2 Sensor Heating Circ., Bank 2-Sensor1 Short to B +
17516
P1108
O2 Sensor Heating Circ., Bank 2-Sensor1 Output Too Low
17517
P1109
O2 Sensor Circ., Bank 2-sensor2 Voltage Too Low / Air Leak
17518
P1110
O2 Sensor Heating Circ., Bank 2-sensor2 Short to B +
17519
P1111
O2 Control (Bank 1) System too lean
17520
P1112
O2 Control (Bank 1) System too rich
17521
P1113
Bank1-Sensor1 Internal Resistance too High
17522
P1114
Bank1-sensor2 Internal Resistant Too High
17523
P1115
O2 Sensor Heater Circ., Bank1-Sensor1 Short to Ground
17524
P1116
O2 Sensor Heater Circ., Bank1-Sensor1 Open
17525
P1117
O2 Sensor Heater Circ., Bank1-sensor2 Short to Ground
17526
P1118
O2 Sensor Heater Circ., Bank1-sensor2 Open
17527
P1119
O2 Sensor Heater Circ., Bank 2-Sensor1 Short to Ground
17528
P1120
O2 Sensor Heater Circ., Bank 2-Sensor1 Open
17529
P1121
O2 Sensor Heater Circ., Bank 2-sensor2 Short to Ground
17530
P1122
O2 Sensor Heater Circ., Bank 2-sensor2 Open
17531
P1123
Long Term Fuel Trim Add.Air., Bank1 System too Rich
17532
P1124
Long Term Fuel Trim Add.Air., Bank1 System too Lean
17533
P1125
Long Term Fuel Trim Add.Air., Bank 2 System Too Rich
17534
P1126
Long Term Fuel Trim Add.Air., Bank 2 System Too Lean
17535
P1127
Long Term Fuel Trim mult., Bank1 System too Rich
17536
P1128
Long Term Fuel Trim mult., Bank1 System too Lean
17537
P1129
Long Term Fuel Trim mult., Bank 2 System Too Rich
17538
P1130
Long Term Fuel Trim mult., Bank 2 System Too Lean
17539
P1131
Bank 2-Sensor1 Internal rsistance Too High
17540
P1132
O2 Sensor Heating Circ., Bank1 + 2 Sensor1 Short to B +
17541
P1133
O2 Sensor Heating Circ., Bank1 + 2 Sensor1 Electrical Malfunction
17542
P1134
O2 Sensor Heating Circ., Bank1 + 2 sensor2 Short to B +
17543
P1135
O2 Sensor Heating Circ., Bank1 + 2 sensor2 Electrical Malfunction
17544
P1136
Long Term Fuel Trim Add.Fuel, Bank1 System too Lean
17545
P1137
Long Term Fuel Trim Add.Fuel, Bank1 System too Rich
17546
P1138
Long Term Fuel Trim Add.Fuel, Bank 2 System Too Lean
17547
P1139
Long Term Fuel Trim Add.Fuel, Bank 2 System Too Rich
17548
P1140
Bank 2-sensor2 Internal Resistance too High
17549
P1141
Load Calculation Crosscheck Range / Performance
17550
P1142
Load Calculation Cross Check Lower Limit Exceeded
17551
P1143
Load Calculation Cross Check Upper Limit Exceeded
17552
P1144
Mass or Volume Air Flow Circ Open / Short to Ground
17553
P1145
Mass or Volume Air Flow Circ Short to B +
17554
P1146
Mass or Volume Air Flow Circ Supply Malfunction
17555
P1147
O2 Control (Bank 2) System too lean
17556
P1148
O2 Control (Bank 2) System too rich
17557
P 1149
O2 Control (Bank 1) Out of range
17558
P1150
O2 Control (Bank 2) Out of range
17559
P1151
Bank1, Long Term Fuel Trim, Range 1 Lean Ness Lower Limit Exceeded
17560
P1152
Bank1, Long Term Fuel Trim, Range 2 Lean Ness Lower Limit Exceeded
17562
P1154
Manifold Switchover Malfunction
17563
P1155
Manifold Abs.Pressure Sensor Circ. Short to B +
17564
P1156
Manifold Abs.Pressure Sensor Circ. Open / Short to Ground
17565
P1157
Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
17566
P1158
Manifold Abs.Pressure Sensor Circ. Range / Performance
17568
P1160
Manifold temperature sensor Circ. Short to Ground
17569
P1161
Manifold temperature sensor Circ. Open / Short to B +
17570
P1162
Fuel temperature sensor Circ. Short to Ground
17571
P1163
Fuel temperature sensor Circ. Open / Short to B +
17572
P1164
Fuel Temperature Sensor Range / Performance / Incorrect Signal
17573
P1165
Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
17574
P1166
Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
17579
P1171
Throttle Actuation Potentiometer Sign.2 Range / Performance
17580
P1172
Throttle Actuation Potentiometer Sign.2 Signal too Low
17581
P1173
Throttle Actuation Potentiometer Sign.2 Signal too High
17582
P1174
Fuel Trim, Bank 1 Different injection times
17584
P1176
O2 Correction Behind Catalyst B1 Limit Attained
17585
P1177
O2 Correction Behind Catalyst, B2 Limit Attained
17586
P1178
Linear 02 Sensor / Pump Current Open Circuit
17587
P1179
Linear 02 Sensor / Pump Current Short to ground
17588
P1180
Linear 02 Sensor / Pump Current Short to B +
17589
P1181
Linear 02 Sensor / Reference Open Circuit Voltage
17590
P1182
Linear 02 Sensor / Reference Voltage Short to ground
17591
P1183
Linear 02 Sensor / Reference Voltage Short to B +
17592
P1184
Linear 02 Sensor / Common Ground Wire Open Circuit
17593
P1185
Linear 02 Sensor / Common Ground Wire Short to ground
17594
P1186
Linear 02 Sensor / Common Ground Wire Short to B +
17595
P1187
Linear 02 Sensor / Compens. Resistor Circuit Open
17596
P1188
Linear 02 Sensor / Compens. Resistor Short to ground
17597
P1189
Linear 02 Sensor / Compens. Resistor Short to B +
17598
P1190
Linear 02 Sensor / Reference Voltage Incorrect Signal
17604
P1196
O2 Sensor Heater Circ., Bank1-Sensor1 Electrical Malfunction
17605
P1197
O2 Sensor Heater Circ., Bank 2-Sensor1 Electrical Malfunction
17606
P1198
O2 Sensor Heater Circ., Bank1-sensor2 Electrical Malfunction
17607
P1199
O2 Sensor Heater Circ., Bank 2-sensor2 Electrical Malfunction
17609
P1201
Cyl.1-Fuel Inj.Circ. Electrical Malfunction
17610
P1202
Cyl.2-Fuel Inj.Circ. Electrical Malfunction
17611
P1203
Cyl.3-Fuel Inj.Circ. Electrical Malfunction
17612
P1204
Cyl.4-Fuel Inj.Circ. Electrical Malfunction
17613
P1205
Cyl.5-Fuel Inj.Circ. Electrical Malfunction
17614
P1206
Cyl.6-Fuel Inj.Circ. Electrical Malfunction
17615
P1207
Cyl.7-Fuel Inj.Circ. Electrical Malfunction
17616
P1208
Cyl.8-Fuel Inj.Circ. Electrical Malfunction
17617
P1209
Intake valves for cylinder shut-off Short circuit to ground
17618
P1210
Intake valves for cylinder shut-off Short to B +
17619
P1211
Intake valves for cylinder shut-off Open circuit
17621
P1213
Cyl.1-Fuel Inj.Circ. Short to B +
17622
P1214
Cyl.2-Fuel Inj.Circ. Short to B +
17623
P1215
Cyl.3-Fuel Inj.Circ. Short to B +
17624
P1216
Cyl.4-Fuel Inj.Circ. Short to B +
17625
P1217
Cyl.5-Fuel Inj.Circ. Short to B +
17626
P1218
Cyl.6-Fuel Inj.Circ. Short to B +
17627
P1219
Cyl.7-Fuel Inj.Circ. Short to B +
17628
P1220
Cyl.8-Fuel Inj.Circ. Short to B +
17629
P1221
Cylinder shut-off valves exhaust Short circuit to ground
17630
P1222
Cylinder shut-off exhaust valves Short to B +
17631
P1223
Cylinder shut-off exhaust valves Open circuit
17633
P1225
Cyl.1-Fuel Inj.Circ. Short to Ground
17634
P1226
Cyl.2-Fuel Inj.Circ. Short to Ground
17635
P1227
Cyl.3-Fuel Inj.Circ. Short to Ground
17636
P1228
Cyl.4-Fuel Inj.Circ. Short to Ground
17637
P1229
Cyl.5-Fuel Inj.Circ. Short to Ground
17638
P1230
Cyl.6-Fuel Inj.Circ. Short to Ground
17639
P1231
Cyl.7-Fuel Inj.Circ. Short to Ground
17640
P1232
Cyl.8-Fuel Inj.Circ. Short to Ground
17645
P1237
Cyl.1-Fuel Inj.Circ. Open Circ.
17646
P1238
Cyl.2-Fuel Inj.Circ. Open Circ.
17647
P1239
Cyl.3-Fuel Inj.Circ. Open Circ.
17648
P1240
Cyl.4-Fuel Inj.Circ. Open Circ.
17649
P1241
Cyl.5-Fuel Inj.Circ. Open Circ.
17650
P1242
Cyl.6-Fuel Inj.Circ. Open Circ.
17651
P1243
Cyl.7-Fuel Inj.Circ. Open Circ.
17652
P1244
Cyl.8-Fuel Inj.Circ. Open Circ.
17653
P1245
Needle Lift Sensor Circ. Short to Ground
17654
P1246
Needle Lift Sensor Circ. Range / Performance
17655
P1247
Needle Lift Sensor Circ. Open / Short to B +
17656
P1248
Injection Start Control Deviation
17657
P1249
Fuel consumption signal Electrical Fault in Circuit
17658
P1250
Fuel Level Too Low
17659
P1251
Start of Injection Solenoid Circ Short to B +
17660
P1252
Start of Injection Solenoid Circ Open / Short to Ground
17661
P1253
Fuel consumption signal Short to ground
17662
P1254
Fuel consumption signal Short to B +
17663
P1255
Engine Coolant Temp.Circ Short to Ground
17664
P1256
Engine Coolant Temp.Circ Open / Short to B +
17665
P1257
Engine Coolant System Valve Open
17666
P1258
Engine Coolant System Valve Short to B +
17667
P1259
Engine Coolant System Valve Short to Ground
17688
P1280
Fuel Inj.Air Contr.Valve Circ. Flow Too Low
17691
P1283
Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
17692
P1284
Fuel Inj.Air Contr.Valve Circ. Open
17693
P1285
Fuel Inj.Air Contr.Valve Circ. Short to Ground
17694
P1286
Fuel Inj.Air Contr.Valve Circ. Short to B +
17695
P1287
Turbocharger bypass valve open
17696
P1288
Turbocharger Bypass Valve Short to B +
17697
P1289
Turbocharger Bypass Valve Short to ground
17704
P1296
Cooling System Malfunction
17705
P1297
Connection turbocharger - throttle valve pressure hose
17708
P1300
Misfire detected Reason: Fuel level too low
17721
P1319
Knock Sensor 1 Circ. Short to Ground
17728
P1320
Knock Sensor 2 Circ. Short to Ground
17729
P1321
Knock Sensor 3 Circ. Low Input
17730
P1322
Knock Sensor 3 Circ. High Input
17731
P1323
Knock Sensor 4 Circ. Low Input
17732
P1324
Knock Sensor 4 Circ. High Input
17733
P1325
Cyl.1 Knock-Contr. Limit Attained
17734
P1326
Cyl.2 Knock-Contr. Limit Attained
17735
P1327
Cyl.3 Knock-Contr. Limit Attained
17736
P1328
Cyl.4 Knock-Contr. Limit Attained
17737
P1329
Cyl.5 Knock-Contr. Limit Attained
17738
P1330
Cyl.6 Knock-Contr. Limit Attained
17739
P1331
Cyl.7 Knock-Contr. Limit Attained
17740
P1332
Cyl.8 Knock-Contr. Limit Attained
17743
P1335
Engine Torque Monitoring 2 Control Limint Exceeded
17744
P1336
Engine Torque Monitoring Adaptation at limit
17745
P1337
Camshaft Pos.Sensor, Bank1 Short to Ground
17746
P1338
Camshaft Pos.Sensor, Bank1 Open Circ. / Short to B +
17747
P1339
Crankshaft Pos. / Engine Speed Sensor Cross Connected
17748
P1340
Crankshaft- / Camshaft Pos.Sens.Signals Out of Sequence
17749
P1341
Ignition Coil Power Output Stage 1 Short to Ground
17750
P1342
Ignition Coil Power Output Stage 1 Short to B +
17751
P1343
Ignition Coil Power Output Stage 2 Short to Ground
17752
P1344
Ignition Coil Power Output Stage 2 Short to B +
17753
P1345
Ignition Coil Power Output Stage 3 Short to Ground
17754
P1346
Ignition Coil Power Output Stage 3 Short to B +
17755
P1347
Bank 2, Crankshaft- / Camshaft os.Sens.Sign. Out of Sequence
17756
P1348
Ignition Coil Power Output Stage 1 Open Circuit
17757
P1349
Ignition Coil Power Output Stage 2 Open Circuit
17758
P1350
Ignition Coil Power Output Stage 3 Open Circuit
17762
P1354
Modulation Piston Displ.Sensor Circ. Malfunction
17763
P1355
Cyl. 1, ignition circuit, open circuit
17764
P1356
Cyl. 1, ignition circuit Short to B +
17765
P1357
Cyl. 1, ignition circuit Short to ground
17766
P1358
Cyl. 2, ignition circuit, open circuit
17767
P1359
Cyl. 2, ignition circuit Short Circuit to B +
17768
P1360
Cyl. 2, ignition circuit Short Circuit to Ground
17769
P1361
Cyl. 3, ignition circuit, open circuit
17770
P1362
Cyl. 3, ignition circuit Short Circuit to B +
17771
P1363
Cyl. 3, ignition circuit Short Circuit to ground
17772
P1364
Cyl. 4 ignition circuit Open Circuit
17773
P1365
Cyl. 4 ignition circuit Short circuit to B +
17774
P1366
Cyl. 4 ignition circuit Short circuit to ground
17775
P1367
Cyl. 5, ignition circuit, open circuit
17776
P1368
Cyl. 5, ignition circuit Short Circuit to B +
17777
P1369
Cyl. 5, ignition circuit short to ground
17778
P1370
Cyl. 6 ignition circuit Open Circuit
17779
P1371
Cyl. 6, ignition circuit Short Circuit to B +
17780
P1372
Cyl. 6, ignition circuit short to ground
17781
P1373
Cyl. 7, ignition circuit, open circuit
17782
P1374
Cyl. 7, ignition circuit Short Circuit to B +
17783
P1375
Cyl. 7, ignition circuit short to ground
17784
P1376
Cyl. 8, ignition circuit, open circuit
17785
P1377
Cyl. 8, ignition circuit Short Circuit to B +
17786
P1378
Cyl. 8, ignition circuit short to ground
17794
P1386
Internal Control Module Knock Control Circ.Error
17795
P1387
Internal Contr. Module altitude sensor error
17796
P1388
Internal Contr. Module drive by wire error
17799
P1391
Camshaft Pos.Sensor, Bank 2 Short to Ground
17800
P1392
Camshaft Pos.Sensor, Bank2 Open Circ. / Short to B +
17801
P1393
Ignition Coil Power Output Stage 1 Electrical Malfunction
17802
P1394
Ignition Coil Power Output Stage 2 Electrical Malfunction
17803
P1395
Ignition Coil Power Output Stage 3 Electrical Malfunction
17804
P1396
Engine Speed Sensor Missing Tooth
17805
P1397
Engine speed wheel Adaptation LIMIT REACHED
17806
P1398
Engine RPM signal, TD Short to ground
17807
P1399
Engine RPM signal, TD Short Circuit to B +
17808
P1400
EGR Valve Circ Electrical Malfunction
17809
P1401
EGR Valve Circ Short to Ground
17810
P1402
EGR Valve Circ Short to B +
17811
P1403
EGR Flow Deviation
17812
P1404
EGR Flow Basic Setting not carried out
17814
P1406
EGR temperature sensor Range / Performance
17815
P1407
EGR temperature sensor Signal too Low
17816 P1408 EGR temperature sensor Signal too High
17817
P1409
Tank Ventilation Valve Circ.Electrical Malfunction
17818
P1410
Tank Ventilation Valve Circ. Short to B +
17819 P1411 Sec.Air Inj.Sys., Bank2 Flow too Flow 17820 P1412 EGR Different.Pressure Sensor Signal too Low 17821
P1413
Different.Pressure EGR Sensor Signal Too High
17822
P1414
Sec.Air Inj.Sys., Bank 2 Leak Detected
17825 P1417 Fuel Level Sensor Circ Signal too Low 17826 P1418 Fuel Level Sensor Circ Signal too High
17828
P1420 Sec.Air Inj.Valve Circ Electrical Malfunction 17829 P1421 Sec.Air Inj.Valve Circ Short to Ground
17830
P1422 Sec.Air Inj.Sys.Contr.Valve Circ Short to B + 17831 P1423 Sec.Air Inj.Sys., Bank1 Flow Too Low
17832
P1424 Sec.Air Inj.Sys., Bank1 Leak Detected
17833
P1425 Tank Vent.Valve Short to Ground 17834 P1426 Tank Vent.Valve Open 17840 P1432 Sec.Air Inj.Valve Open 17841 P1433 Sec.Air Inj.Sys.Pump Relay Circ.
open
17842 P1434 Sec.Air Inj.Sys.Pump Relay Circ.
Short to B +
17843 P1435 Sec.Air Inj.Sys.Pump Relay Circ. Short to ground 17844 P1436 Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction 17847 P1439 EGR Potentiometer Error in Basic Seting 17848 P1440 EGR Valve Power Stage Open 17849 P1441 EGR Valve Circ Open / Short to Ground 17850
P1442
EGR Valve Position Sensor Signal too high
17851
P1443
EGR Valve Position Sensor Signal too low
17852
P1444
EGR Valve Position Sensor Range / Performance
17853
P1445
Catalyst temperature sensor 2 Circ. Range / Performance
17854 P1446 Catalyst Temp.Circ Short to Ground 17855 P1447 Catalyst Temp.Circ Open / Short to B + 17856 P1448 Catalyst temperature sensor 2 Circ.
Short to Ground
17857 P1449 Catalyst temperature sensor 2 Circ. Open / Short to B + 17858 P1450 Sec.Air Inj.Sys.Circ Short to B +
17859
P1451 Sec.Air Inj.Sys.Circ Short to Ground 17860
P1452
Sec.Air Inj.Sys. Open Circ.
17861 P1453 Exhaust gas temperature sensor 1 open / short to B + 17862 P1454 Exhaust gas temperature sensor 1 short to ground
17863
P1455
Exhaust gas temperature sensor 1 Range / Performance
17864 P1456 Exhaust gas temperature control bank 1 limit attained 17865 P1457 Exhaust gas temperature sensor 2 open / short to B + 17866 P1458 Exhaust gas temperature sensor 2 short to ground 17867 P1459 Exhaust gas temperature sensor 2 range / performance 17868
P1460
Exhaust gas temperature control couch 2 limit attained
17869 P1461 Exhaust gas temperature control bank 1 Range / Performance 17870 P1462 Exhaust gas temperature control couch 2 Range / Performance
17873
P1465 Additive Pump Short Circuit to B +
17874
P1466 Additive Pump Open / Short to Ground 17875 P1467 EVAP Canister Purge Solenoid Valve Short Circuit to B + 17876 P1468 EVAP Canister Purge Solenoid Valve Short Circuit to Ground 17877 P1469 EVAP Canister Purge Solenoid Valve Open Circuit 17878 P1470 EVAP Emission Contr.LDP Circ Electrical Malfunction 17879 P1471 EVAP Emission Contr.LDP Circ Short to B + 17880 P1472 EVAP Emission Contr.LDP Circ Short to Ground 17881
P1473
EVAP Emission Contr.LDP Circ Open Circ.
17882
P1474
EVAP Canister Purge Solenoid Valve electrical Malfunction
17883 P1475 EVAP Emission Contr.LDP Circ Malfunction / Signal Circ.Open 17884 P1476 EVAP Emission Contr.LDP Circ Malfunction / Insufficient Vacuum 17885 P1477 EVAP Emission Contr.LDP Circ Malfunction 17886 P1478 EVAP Emission Contr.LDP Circ Clamped Tube Detected 17908
P1500
Fuel Pump Relay Circ.Electrical Malfunction
17909
P1501
Fuel Pump Relay Circ. Short to Ground
17910
P1502
Fuel Pump Relay Circ. Short to B +
17911 P1503 Load signal from Alternator Term. DF Range / Performance / Incorrect Signal 17912
P1504
Intake Air Sys.Bypass Leak Detected
17913 P1505 Closed Throttle Pos. Does Not Close / Open Circ 17914 P1506 Closed Throttle Pos.Switch Does Not Open / Short to Ground 17915
P1507
Idle Sys.Learned Value Lower Limit Attained
17916 P1508 Idle Sys.Learned Value Upper Limit Attained 17917 P1509 Idle Air Control Circ. Electrical Malfunction 17918
P1510
Idle Air Control Circ. Short to B +
17919 P1511 Intake Manifold Changeover Valve circuit electrical malfunction 17920
P1512
Intake Manifold Changeover Valve circuit Short to B +
17921 P1513 Intake Manifold Changeover Valve2 Short circuit to B + 17922 P1514 Intake Manifold Changeover Valve2 Short circuit to ground 17923 P1515 Intake Manifold Changeover Valve circuit Short to Ground 17924
P1516
Intake Manifold Changeover Valve Open circuit
17925
P1517
Main Relay Circ.Electrical Malfunction
17926
P1518
Main Relay Circ. Short to B +
17927 P1519 Intake Camshaft Contr., Bank1 Malfunction 17928 P1520 Intake Manifold Changeover Valve2 circuit Open 17929 P1521 Intake Manifold Changeover Valve2 circuit electrical Malfunction 17930 P1522 Intake Camshaft Contr., Bank 2 Malfunction 17931 P1523 Crash Signal from Airbag Control Unit Range / Performance 17933 P1525 Intake Camshaft Contr.Circ., Bank1 Electrical Malfunction 17934 P1526 Intake Camshaft Contr.Circ., Bank1 Short to B + 17935 P1527 Intake Camshaft Contr.Circ., Bank1 Short to Ground 17936 P1528 Intake Camshaft Contr.Circ., Bank1 Open 17937 P1529 Camshaft Control Circuit Short to B + 17938
P1530
Camshaft Control Circuit Short to ground
17939 P1531 Camshaft Control Circuit Open 17941 P1533 Intake Camshaft Contr.Circ., Bank 2 Electrical Malfunction 17942 P1534 Intake Camshaft Contr.Circ., Bank 2 Short to B + 17943 P1535 Intake Camshaft Contr.Circ., Bank 2 Short to Ground 17944 P1536 Intake Camshaft Contr.Circ., Bank2 Open 17945 P1537 Engine Shutoff Solenoid Malfunction 17946 P1538 Engine Shutoff Solenoid Open / Short to Ground 17947 P1539 Clutch Vacuum Vent Valve Switch Incorrect signal 17948 P1540 Vehicle Speed Sensor Input High 17949 P1541 Fuel Pump Relay Circ Open 17950 P1542 Throttle Actuation Potentiometer Range / Performance 17951 P1543 Throttle Actuation Potentiometer Signal too Low 17952 P1544 Throttle Actuation Potentiometer Signal too High 17953 P1545 Throttle Pos.Contr Malfunction 17954 P1546 Boost Pressure Contr.Valve Short to B + 17955 P1547 Boost Pressure Contr.Valve Short to Ground 17956 P1548 Boost Pressure Contr.Valve Open 17957
P1549
17958
P1550
Charge Pressure Deviation
17959 P1551 Barometric Pressure Sensor Circ.
Short to B +
17960 P1552 Barometric Pressure Sensor Circ. Open / Short to Ground 17961 P1553 Barometric / manifold pressure signal ratio out of range 17962 P1554 Idle Speed Contr.Throttle Pos. Basic Setting Conditions not with 17963 P1555 Charge Pressure Upper Limit exceeded 17964 P1556 Charge Pressure Contr. Negative Deviation
17965
P1557 Charge Pressure Contr. Positive Deviation 17966 P1558 Throttle Actuator Electrical Malfunction 17967 P1559 Idle Speed Contr.Throttle Pos. Adaptation Malfunction 17968 P1560 Maximum Engine Speed Exceeded 17969 P1561 Quantity Adjuster Deviation 17970 P1562 Quantity Adjuster Upper Limit Attained 17971 P1563 Quantity Adjuster Lower Limit Attained 17972 P1564 Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation 17973 P1565 Idle Speed Control Throttle Position lower limit not attained 17974 P1566 Load signal from A / C compressor range / Performance 17975 P1567 Load signal from A / C compressor no signal 17976 P1568 Idle Speed Contr.Throttle Pos. Mechanical Malfunction 17977 P1569 Cruise Control Switch Incorrect signal 17978 P1570 Contr.Module Locked 17979 P1571 Left Eng. Mount Solenoid Valve Short to B + 17980 P1572 Left Eng. Mount Solenoid Valve Short to ground 17981 P1573 Left Eng. Mount Solenoid Valve Open circuit 17982 P1574 Left Eng. Mount Solenoid Valve Electrical fault in circuit 17983 P1575 Right Eng. Mount Solenoid Valve Short to B + 17984 P1576 Right Eng. Mount Solenoid Valve Short to ground 17985 P1577 Right Eng. Mount Solenoid Valve Open circuit 17986 P1578 Right Eng. Mount Solenoid Valve Electrical fault in circuit 17987 P1579 Idle Speed Contr.Throttle Pos. Adaptation not started 17988 P1580 Throttle Actuator B1 Malfunction 17989 P1581 Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out 17990 P1582 Idle Adaptation at limit 17991 P1583 Transmission mount valves Short to B + 17992 P1584 Transmission mount valves Short to ground 17993 P1585 Transmission mount valves Open circuit 17994 P1586 Engine mount solenoid valves Short to B + 17995 P1587 Engine mount solenoid valves Short to ground 17996 P1588 Engine mount solenoid valves Open circuit 18008 P1600 Power Supply (B +) Terminal 15 Low Voltage 18010 P1602 Power Supply (B +) Terminal 30 Low Voltage 18011 P1603 Internal Control Module Malfunction 18012 P1604 Internal Control Module Driver Error 18013 P1605 Rough Road / Acceleration Sensor Electrical Malfunction 18014 P1606 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
18015
P1607 Vehicle speed signal Error message from instrument cluster 18016 P1608 Steering angle signal Error message from steering angle sensor 18017 P1609 Crash shut-down activated 18019 P1611 MIL Call-up Circ. / Transm.Contr.Module Short to Ground
18020
P1612 Electronic Control Module Incorrect Coding
18021
P1613 MIL Call-up Circ Open / Short to B + 18022 P1614 MIL Call-up Circ. / Transm.Contr.Module Range / Performance 18023 P1615 Engine Oil Temperature Sensor Circuit Range / Performance 18024 P1616 Glow Plug / Heater Indicator Circ.
Short to B +
18025 P1617 Glow Plug / Heater Indicator Circ. Open / Short to Ground 18026 P1618 Glow Plug / Heater Relay Circ.
Short to B +
18027 P1619 Glow Plug / Heater Relay Circ. Open / Short to Ground 18028 P1620 Engine coolant temperature signal open / short to B +
18029
P1621 Engine coolant temperature signal short to ground 18030 P1622 Engine coolant temperature signal Range / Performance 18031 P1623 Data Bus Powertrain No Communication 18032 P1624 MIL Request Sign.active 18033
P1625
Data Bus Powertrain Unplausible Message from Transm.Contr.
18034 P1626 Data Bus Powertrain Missing Message from Transm.Contr. 18035 P1627 Data Bus Powertrain missing message from fuel injection pump 18036 P1628 Data Bus Powertrain missing message from steering sensor 18037 P1629 Data bus Powertrain missing message from distance control 18038 P1630 Accelera.Pedal Pos.Sensor 1 Signal too Low 18039 P1631 Accelera.Pedal Pos.Sensor 1 Signal too High 18040 P1632 Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction 18041 P1633 Accelera.Pedal Pos .Sensor 2 Signal too Low 18042 P1634 Accelera.Pedal Pos.Sensor 2 Signal too High 18043 P1635 Data Bus Powertrain missing message f.air condition control 18044 P1636 Data Bus Powertrain Missing message from airbag control 18045 P1637 Data Bus Powertrain missing message f.central electr.control 18046 P1638 Data Bus Powertrain missing message from clutch control 18047 P1639 Accelera.Pedal Pos.Sensor 1 + 2 Range / Performance 18048 P1640 Internal Contr.Module (EEPROM) Error 18049 P1641 Please check DTC Memory of Air Condition ECU 18050 P1642 Please Check DTC Memory of Airbag ECU 18051 P1643 Please check DTC Memory of central electric ECU 18052 P1644 Please check DTC Memory of clutch ECU 18053 P1645 Data Bus Powertrain missing message F.All wheel drive contr. 18054 P1646 Please check DTC Memory of all wheel drive ECU
18055
P1647 Please check coding or ECUs in Data Bus Powertrain 18056 P1648 Data Bus Powertrain Malfunction
18057
P1649 Data Bus Powertrain Missing message from ABS Control Module 18058
P1650
Data Bus Powertrain Missing message fr.instrument panel ECU
18059
P1651
Data Bus Powertrain missing messages
18060 P1652 Please check DTC Memory of transmission ECU 18061 P1653 Please check DTC Memory of ABS Control Module 18062 P1654 Please check DTC Memory of control panel ECU 18063 P1655 Please check DTC Memory of ADR Control Module 18064 P1656 A / C clutch relay circuit short to ground 18065 P1657 A / C clutch relay circuit short to B + 18066 P1658 Data Bus Powertrain Incorrect signal from ADR Control Module 18084 P1676 Drive by Wire-MIL Circ. Electrical Malfunction 18085 P1677 Drive by Wire-MIL Circ.
Short to B +
18086 P1678 Drive by Wire-MIL Circ.
Short to Ground
18087 P1679 Drive by Wire-MIL Circ.
Open
18089 P1681 Contr.Unit Programming, Programming not Finished 18092 P1684 Contr.Unit Programming Communication Error 18094 P1686 Contr.Unit Error Programming Error 18098 P1690 Malfunction Indication Light Malfunction 18099 P1691 Malfunction Indication Light Open
18100
P1692 Malfunction Indication Light Short to Ground 18101 P1693 Malfunction Indication Light Short to B + 18102 P1694 Malfunction Indication Light Open / Short to Ground 18112
P 1704
Kickdown Switch Malfunction
18113
P1705
Gear / Ratio Monitoring Adaptation LIMIT REACHED
18119
P1711
Wheel Speed Signal 1 Range / Performance
18124 P1716 Wheel Speed Signal 2 Range / Performance 18129 P1721 Wheel Speed Signal 3 Range / Performance 18131 P1723
Starter Interlock Circ. Open
18132 P1724
Starter Interlock Circ. Short to Ground
18134
P1726 Wheel Speed Signal 4 Range / Performance 18136 P1728 Wheel Speed Differential Signals Range / Performance 18137
P1729
Starter Interlock Circ. Short to B +
18141 P1733 Tiptronic Switch Down Circ.
Short to Ground
18147 P1739 Tiptronic Switch up Circ.
Short to Ground
18148
P1740
Clutch temperature control
18149
P1741
Clutch Pressure adaptation at limit
18150 P1742 Clutch torque adaptation at limit 18151 P1743 Clutch slip control signal too high 18152
P1744
Tiptronic Switch Recognition Circ. Short to Ground
18153
P1745
Transm.Contr.Unit Relay Short to B +
18154
P1746
Transm.Contr.Unit Relay Malfunction
18155 P1747 Transm.Contr.Unit Relay Open / Short to Ground 18156 P1748 Transm.Contr.Unit Self-Check 18157
P1749
Transm.Contr.Unit Incorrectly Coded
18158 P1750 Power Supply Voltage Low Voltage 18159
P1751
Power Supply Voltage High Voltage
18160 P1752 Power Supply Malfunction 18168
P1760
Shift Lock Malfunction
18169
P1761
Shift Lock Short to Ground
18170
P1762
Shift Lock Short to B +
18171 P1763 Shift Lock Open 18172 P1764 Transmission temperature control 18173 P1765 Hydraulic Pressure Sensor 2 adaptation at limit 18174 P1766 Throttle Angle Signal Stuck Off 18175
P1767
Throttle Angle Signal Stuck On
18176 P1768 Hydraulic Pressure Sensor 2 Too High 18177 P1769 Hydraulic Pressure Sensor 2 Too Low 18178 P1770 Load Signal Range / Performance 18179 P1771 Load Signal Stuck Off 18180 P1772 Load Signal Stuck On 18181 P1773 Hydraulic Pressure Sensor 1 Too High 18182 P1774 Hydraulic Pressure Sensor 1 Too Low 18183 P1775 Hydraulic Pressure Sensor 1 Adaptation at limit 18184 P1776 Hydraulic Pressure Sensor 1 Range / Performance 18185 P1777 Hydraulic Pressure Sensor 2 range / performance
18186
P1778 Solenoid EV7 Electrical Malfunction 18189
P1781
Engine Torque Reduction Open / Short to Ground
18190 P1782 Engine Torque Reduction Short to B + 18192
P1784
Shift up / down Wire Open / Short to Ground
18193
P1785
Shift up / down Wire Short to B +
18194
P1786
Reversing Light Circ. Open
18195 P1787
Reversing Light Circ. Short to Ground
18196
P1788
Reversing Light Circ. Short to B +
18197 P1789 Idle Speed Intervention Circ. Error Message from Engine Contr. 18198 P1790 Transmission Range Display Circ.
Open
18199 P1791 Transmission Range Display Circ.
Short to Ground
18200
P1792 Transmission Range Display Circ.
Short to B +
18201 P1793 Output Speed Sensor 2 Circ.
No Signal
18203 P1795 Vehicle Speed Signal Circ.
Open
18204 P1796 Vehicle Speed Signal Circ.
Short to Ground
18205 P1797 Vehicle Speed Signal Circ.
Short to B +
18206 P1798 Output Speed Sensor 2 Circ. Range / Performance 18207 P1799 Output Speed Sensor 2 Circ. Rpm too High 18221 P1813 Pressure Contr.Solenoid 1 Electrical
18222
P1814 Pressure Contr.Solenoid 1 Open / Short to Ground 18223 P1815 Pressure Contr.Solenoid 1 Short to B + 18226 P1818 Pressure Contr.Solenoid 2 Electrical 18227 P1819 Pressure Contr.Solenoid 2 Open / Short to Ground 18228 P1820 Pressure Contr.Solenoid 2 Short to B + 18231 P1823 Pressure Contr.Solenoid 3 Electrical 18232 P1824 Pressure Contr.Solenoid 3 Open / Short to Ground 18233 P1825 Pressure Contr.Solenoid 3 Short to B + 18236 P1828 Pressure Contr.Solenoid 4 Electrical 18237 P1829 Pressure Contr.Solenoid 4 Open / Short to Ground 18238 P1830 Pressure Contr.Solenoid 4 Short to B + 18242 P1834 Pressure Contr.Solenoid 5 Open / Short to Ground 18243 P1835 Pressure Contr.Solenoid 5 Short to B + 18249 P1841 Engine / Transmission Control Modules Versions do not match 18250 P1842 Please check DTC Memory or instrument panel ECU 18251 P1843 Please check DTC Memory of ADR Control Module 18252 P1844 Please check DTC Memory of central electric control ECU
18255
P1847 Please check DTC Memory of brake system ECU 18256 P1848 Please check DTC Memory of engine ECU 18257 P1849 Please check DTC Memory of transmission ECU 18258 P1850 Data Bus Powertrain Missing Message from Engine Contr. 18259 P1851 Data Bus Powertrain Missing Message from Brake Contr . 18260 P1852 Data Bus Powertrain Unplausible Message from Engine Contr.
18261
P1853 Data Bus Powertrain Unplausible Message from Brake Contr. 18262 P1854 Data Bus Powertrain Hardware Defective 18263 P1855 Data Bus Powertrain Software version Contr.
18264
P1856 Throttle / Pedal Pos.Sensor A Circ. Error Message from Engine Contr. 18265 P1857 Load Signal Error Message from Engine Contr.
18266
P1858 Engine Speed Input Circ. Error Message from Engine Contr.
18267
P1859 Brake Switch Circ. Error Message from Engine Contr. 18268 P1860 Kickdown Switch Error Message from Engine Contr. 18269 P1861 Throttle Position (TP) sensor Error Message from ECM 18270 P1862 Data Bus Powertrain Missing message from Instr. panel ECU 18271 P1863 Data Bus Powertrain Missing Message from St. Angle Sensor
18272
P1864 Data Bus Powertrain Missing message from ADR Control Module 18273 P1865 Data Bus Powertrain Missing message from central electronics 18274 P1866 Data Bus Powertrain Missing messages
