julgo que seja o AJM
pois calma ne. ta bem. posta a i umas fotos do bmw po pessoal ver.![]()
julgo que seja o afn
Pelas fotos não me parece.. A tampa de válvulas, EGR, bomba injectora e pois uns pormenores são diferentes no AFN. Parece ser injector bomba. AJM?!?
Está bonita a carrinha. Saca essa protecção do volante e pinta as madeiras![]()
UMMMMM... ok os audis sao audis..lol vou ver o que diz na lata...
As this has been asked on several occasions I thought it would be wise to explain the background to the VW 505.01 oil and why it's so important to use it in a PD engine.
It is vitally important to use a PD oil in the PD engine due to the pump.
The VW pd engines are very severe on the oil, the mechanical fuel pump delivers fuel at approx. 25,000 psi !!!!! to enable a very precise injector spray pattern which, in turn, gives excellent driving characteristics.
The very high loads on the fuel pump will lead to VI improver shear down and oil viscosity loss if the engine is operated on lesser oils.
The surest way to shorten the life of your engine is to ignore this advice.
SEAT Forum : SEAT Enthusiasts • View topic - Why is VW 505.01 oil important in a PD engine - The answer!
25000psi!!! fds...
