19559/P3103 - Motor for Intake Manifold Flap (V157), Malfunction
Possible Symptoms
* Higher fuel consumption
* Insufficient acceleration above 100-120 kmh
* Shutting off the engine is not nice and easy
Possible Causes
* Intake Manifold Flap (V157) or the motor for V157 doesn't work well.
Possible Solutions
* Check wiring and connections
* Check / Replace V157, but probably you have to replace the whole EGR
Special Notes
* The Intake Manifold Flap (V157) has a function in the EGR and in shutting off the (diesel) engine.
16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected
Possible Symptoms
* Malfunction Indicator Light (MIL) ON
* Reduced Exhaust Gas Recirculation (EGR)
* Reduced Power Output/Engine running rough
* Increased Emissions
Possible Causes
* Exhaust Gas Recirculation (EGR) Flow restricted/clogged
* Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
* Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
* Exhaust Gas Recirculation (EGR) System faulty
Possible Solutions
* Check/Clean Exhaust Gas Recirculation (EGR) System
* Check/Replace Exhaust Gas Recirculation (EGR) Valve
* Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
Isto é a descrição dos erros, agora os mais entendidos que ajudem..
Possible Symptoms
Possible Causes
Possible Solutions
Special Notes
Possible Symptoms
Possible Causes
Possible Solutions
