consegui fazer um scan total e o resultado foi o seguinte:
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Controller: 038 906 019 FP
Component: 1,9l R4 EDC G000SG 1538
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E73A036474 AUZ6Z0B0129231
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 00186
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
01810 - Actuating Motor for Temperature Flap: Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00100
Shop #: WSC 00186
WAUZZZ8E23A180840
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AH
Component: Komfortgerát T1B 0619
Coding: 07018
Shop #: WSC 63351
1 Fault Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 56 -------------------------------------------------------
Controller: 8E0 035 186
Component: concert II GRO 0008
Coding: 00013
Shop #: WSC 63351
3 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00857 - CD Changer Unit (R41)
Address 76 -------------------------------------------------------
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 00114
Shop #: WSC 63351
End -------------------------------------------------------
Coding: 00002
Shop #: WSC 63351
Coding: 04255
Shop #: WSC 00186
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
Coding: 00001
Shop #: WSC 63351
Coding: 00042
Shop #: WSC 63351
Coding: 00100
Shop #: WSC 00186
WAUZZZ8E23A180840
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
Coding: 07018
Shop #: WSC 63351
1 Fault Found:
Coding: 00013
Shop #: WSC 63351
3 Faults Found:
Coding: 00114
Shop #: WSC 63351
