Já agora fica aqui o scan que fiz ao teu carro até á bateria do portatil ir abaixo.
Tens aqui algumas coisas para resolver.
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5934
Coding: 00002
Shop #: WSC 63251
WAUZZZ8E05A038814 AUZ6Z0D0268836
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04255
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AB
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 63251
1 Fault Found
00716 - Air recirculation Flap Positioning Motor (V113)
41-00 - Blocked or No Voltage
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 01001
Shop #: WSC 63251
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 P
Component: Lenksáulenmodul 0611
Coding: 04242
Shop #: WSC 63251
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 T
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00001
Shop #: WSC 00044
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AR
Component: Komfortgerát T85 1512
Coding: 06976
Shop #: WSC 63251
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
1 Fault Found
00956 - Key 2
35-10 - - - Intermittent
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63251
1 Fault Found
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Coding: 00002
Shop #: WSC 63251
Coding: 04255
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63251
1 Fault Found
Coding: 01001
Shop #: WSC 63251
Coding: 0010602
Coding: 04242
Shop #: WSC 63251
Coding: 00001
Shop #: WSC 00044
Coding: 06976
Shop #: WSC 63251
Part No: 8E1959801B
Part No: 8E1959802B
1 Fault Found
00956 - Key 2
Coding: 01001
Shop #: WSC 63251
1 Fault Found
