Tou com um problema, a minha carrinha (Audi A4 B7 2.0 tdi) não pega, a luz de resistência não acende, logo, apesar de chamar bem, nem vale a pena insistir, porque não pega. Liguei ao Vag-Com, e deu-me o seguinte erro:
01314 - Engine Control Module: No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
Fault(s) stored in Engine Control Module
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Engine Control Module
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
Check Engine Control Module for Fault Codes
Special Notes
Engine Control Module stored a Code which influences other Control Modules Functionality.
To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
Retrieved from "http://wiki.ross-tech.com/index.php/01314"
De que se trata??? È coisa complicada? Agradeço a vossa ajuda.
Possible Causes
Possible Solutions
Possible Causes
Possible Solutions
Special Notes
