boas malta....
apos longo time de ausencia por motivos profissionais....sorry
alguem me pode dizer o que sao estes codigos?
Saturday,17,May,2014,17:31:36:37412
VCDS Version: Release 805.0
Data version: 20080529
Chassis Type: 4F0
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61
62 69 72 76 77
VIN: WAUZZZ4F55N058306 Mileage: 153240km/95218miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 BF HW: 028 101 185 0
Component: R4 2,0L EDC G000SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 73911 123 03009
3 Faults Found:
17056 - Can't Decode, CODE File Not Loaded!
P0672 - 000 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
RPM: 0 /min
Torque: 154.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001000
Temperature: 7.2°C
Bin. Bits: 00110000
17057 - Can't Decode, CODE File Not Loaded!
P0673 - 000 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
RPM: 0 /min
Torque: 154.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001000
Temperature: 7.2°C
Bin. Bits: 00110000
17058 - Can't Decode, CODE File Not Loaded!
P0674 - 000 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
RPM: 0 /min
Torque: 154.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001000
Temperature: 7.2°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004471
Shop #: WSC 02325 785 00200
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0130
Revision: 30040401 Serial number: 10600300075082
Coding: 0000001
Shop #: WSC 02323 785 00200
Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H35 0040
1 Fault Found:
00955 - Can't Decode, CODE File Not Loaded!
002 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 19
Reset counter: 179
Mileage: 150143 km
Time Indication: 0
Date: 2014.03.21
Time: 20:00:56
Address 07: Control Head Labels: None
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350II057601046
Coding: 0000001
Shop #: WSC 07897 000 1048576
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
1 Fault Found:
00003 - Can't Decode, CODE File Not Loaded!
005 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 84
Mileage: 149920 km
Time Indication: 0
Date: 2014.03.21
Time: 12:25:30
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000067661
Coding: 0000020
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
Shop #: WSC 02335 785 00200
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
2 Faults Found:
014 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01111110
Fault Priority: 2
Fault Frequency: 4
Reset counter: 139
Mileage: 89712 km
Time Indication: 0
Date: 2007.11.20
Time: 19:07:00
00978 - Can't Decode, CODE File Not Loaded!
010 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 11
Reset counter: 162
Mileage: 152008 km
Time Indication: 0
Date: 2014.04.23
Time: 19:00:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6018354
Shop #: WSC 00000 000 00000
Address 15: Airbags Labels: 4F0-910-655.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 33 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD047AS7
Coding: 0013107
Shop #: WSC 73911 123 51572
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 N
Component: KOMBIINSTR. M73 H09 0630
Revision: 00200000 Serial number: 4HZ3123A4
Coding: 0260043
Shop #: WSC 00666 123 00000
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 080080492700DF
Coding: EDEE53C41B3104
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353L%047593856
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H10 0020
Revision: 00000000 Serial number: '%
Coding: 0000522
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001108810000
Coding: 0000241
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000200126
Coding: 0000018
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000038550
Coding: 0001104
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H10 0020
Revision: 00000000 Serial number: #%
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
1 Fault Found:
01487 - Can't Decode, CODE File Not Loaded!
008 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 175
Mileage: 152648 km
Time Indication: 0
Date: 2014.05.04
Time: 21:19:05
Freeze Frame:
Voltage: 10.97 V
Count: 118
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352JX047566607
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000063937
Part No: 4F0 915 105 C
Component: von VA0 2409300526
Coding: 344630393135313035432056413032343039333030353236
Shop #: WSC 00000 384 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0000002
Address 69: Trailer Labels: 4F0-910-383.lbl
Part No SW: 4F0 910 383 HW: 4F0 907 383
Component: ANHAENGERELEKTR H01 0020
Coding: 0000331
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0000002
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0020
Revision: --.--.-- Serial number: 11730427402642
Coding: 0010006
1 Fault Found:
01543 - Can't Decode, CODE File Not Loaded!
009 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 84
Mileage: 149920 km
Time Indication: 0
Date: 2014.03.21
Time: 12:25:30
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0504HCN7
Coding: 0000006
abraço e obrigado
