Podem me Ajudar...
Boas, hoje aconteceu uma coisa que nunca vi, fiz um scan e deu me erro no abs. ja mudei as pastinhas a pouco tempo e nao sei que se passa, e ja me aconteceu 2 vezes,desligo o caro e volto a ligar e desaparece, se alguem me poder ajudar fica o scan e o video. :S :S
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 1185
Revision: --H42--- Serial number: AUX7Z0FDFNJ0DG
Coding: 0000172
Shop #: WSC 00046 261 89444
1 Fault Found
005785 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 254
Reset counter: 40
Mileage: 40323 km
Time Indication: 0
Date: 2009.07.27
Time: 16:42:25
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.20 V
Bin. Bits: 01000010
Bin. Bits: 00000000
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0023170
Shop #: WSC 06314 000 00000
1 Fault Found
01130 - ABS Operation
008 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 084132 Serial number: 8P0820043AC
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006504909
Coding: E7885F078014100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
6 Faults Found
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 41034 km
Time Indication: 0
Date: 2009.08.07
Time: 17:59:00
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 197
Mileage: 41034 km
Time Indication: 0
Date: 2009.08.07
Time: 17:59:00
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 4
Reset counter: 200
Mileage: 41600 km
Time Indication: 0
Date: 2009.08.16
Time: 00:42:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
01499 - Bulb for High-Beams; Right (M32)
Freeze Frame:
Fault Status: 00111010
Fault Priority: 3
Fault Frequency: 9
Reset counter: 225
Mileage: 41600 km
Time Indication: 0
Date: 2009.08.16
Time: 00:42:00
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 9
Reset counter: 200
Mileage: 41590 km
Time Indication: 0
Date: 2009.08.15
Time: 18:10:00
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 59
Reset counter: 237
Mileage: 41590 km
Time Indication: 0
Date: 2009.08.15
Time: 18:32:00
Freeze Frame:
ON
Voltage: 12.20 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H13 4220
Revision: 91H13422 Serial number: 0037W0G0VPWH
Coding: 0070612
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 HW: 8P0 920 931
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 224DF004066455
Coding: 0005118
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106B230BCB
Coding: BD0F074207000100
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H20004 Serial number: AUX7Z0FDFNJ0DG
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX.lbl
Part No: 8P0 959 801 G
Component: Tuer-SG 020 0110
Coding: 0000120
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9880202002186D298505488AC677
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Revision: 00005 Serial number: 30659635700079
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX.lbl
Part No: 8P0 959 802 G
Coding: 0000120
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
Component: R Concert2+ H15 0220
Revision: 00H15000 Serial number: AUZ1Z3F7204967
Coding: 0010211
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 00067824830634
Coding: 0000113
Shop #: WSC 131071 1023 2097151
É melhor venderes o carro pa pecas pá...
O meu aqui a tempos também acendia mas era só em curvas e fui a oficina, acrescentei oleo e nunca mais fez...
Mas o teu caso parece ser diferente pois estas parado...
Eu não percebo muito disto, mas já tentaste apagar os erros no vag-com? Depois voltam a aparecer?
Tens ai o quadrante que parece uma arvore de natal :P :P :P :P
Não tens luzes no carro :?: :?: :?: tens ai erros de luzes ate dar com um pau...se eu fosse a ti trocava de carro :P :P :P :P
koolboy disse:
Gostavas era de ter um sem luzes nenhumas. :P :P :P :P Nao sei o que e,ao desligar o carro aquilo desaparece nem da tempo para ir ao mecanico nem nada. :S :S
marcoA3 disse:
Eu gosto de andar ás escuras :P :P :P :P :P
Entra pelo oficina dentro com o carro :P :P :P :P
koolboy disse:
Vou ver se vou ao mecanico da mesma pode ser que ao meter as pastinhas aconteceu alguma coisa :S :S
Eu tenho lanternas no carro :green: :green: :green: :green:
marcoA3 disse:
Faz isso mas avisa quando fores ao mecanico é que com as luzes do travão acesas é preciso ter cuidado e assim eu não saio de casa :P :P :P :P :P :P ...estou a brincar...
