E já agora, mostra me onde é falado mal sobre a marca AP? Deves de estar a confundir com outras marcas não? Ou falas só porque é mais barato que um kit KW, Bilstein e afins?
Pode-se mesmo dizer que em cada 100 utilizadores existe 1 ou 2 que podem falar mal, pois aconteceu uma situação x ou y ou por que não rebaixou como queria, entre outros comentários típicos a qual se vê com qualquer outra marca, barato ou caro. Simplesmente trata-se de uma marca com uma relação qualidade/preço acima de qualquer outra marca dentro da mesma gama.
Queres quantos exemplos??!!
AP Coilovers - totalMINI Forums
"I've heard good things about APs and they'll be my choice when I have the money."
"They're a good coilover for the money, but by no means the best.
They'll be firmer, especially as the car is lowered. You'll need them fully set up, ie full geometry alignment at a minimum. Corner weighting is worth doing too."
"APs are a good starting point with coils for the money IMO. Go for it "
"I have got aps think they are great for the money, they go very low i have 7 treads left onthe front and have had to trim the plastic lip under the bumper as its rubbed under breaking. I have the stanard 15s on atm no rubbing. The ride is firm but i like it like that, but it does feel great around coners, got mine from coastal for 550 fitted."
"I had no problems with the AP's regarding ride comfort, but then again I wasn't expecting them to give me the same comfort level as standard suspension, 15" wheels and conventional rubber would. Even to my level of inexperience, I didn't notice a massive difference from the stock suspension when I first had them fitted."
"APs wont be too stiff if thats what youre concerned about... APs are quite a soft coilover as things go... they will be fine "
"Buy the A/Ps, Lohen fitted mine price matched Coastal. No issues at all, go low enough, and ride great. Much better than SS+ suspension and looks so much better."
AP Coilovers.. any reviews?
"Got them fitted on my car. Fitting was easy and good for the price."
"A good choice and a lot better then FK's in my opinion."
"I have been using Ap's now for a couple of months and have had no problems at all.
Great for the money but is quite a firm ride."
ap coilovers
"They are essentially a KW variant 1 but using cheaper components. Needless to say they are pretty spot on, not crashy like eBay coilovers but stiffens the car up nicely compared to the oem setup. I fit these all the time and not had a single complaint."
"A few members are running them gazz, really good reviews"
"I run them on my A4, I've been very impressed so far and they've coped with track work brilliantly. Mine is too low at present all round and I want to bring it up by a good 15mm all round."
"I'm running AP's. Will defo recommend these and they're very comfortable!"
Reviews on AP coilovers - Styling - Club Lupo
"Really good coilovers for the money i cant fault them. They have a much better ride quality than ones i have owned previously owned. Saying that obviously if you spend more you expect better but for the price i can't fault them easy to adjust also. Hope that helps Sam"
"Yeah ive got them on mine, had the cheapest of the cheap on my previous car and the ride is alot better, they can go alot lower than a few lupo coils ive seen and do have okay quality. Not too bangy and not too bouncy, just right.
If you spend more your obviously going to get a better set, but for me i find the AP ones just right, good price for good quality coilovers "
"really good ive had them for a while now and the ride quality is really nice,
there nice and stiff and when u chuck the car into corners it holds the road much better cant recommend them high enough "
Aqui mais....
http://forums.clublupo.co.uk/index.php?showtopic=48860
"AP Coilovers:
Fitted these to my ibiza this week and havent got a bad word to say about them. Great quality, damping seems spot on and smoother than standard at times whilst still being stiffer and car handles 100x better. A big claim but possibly better than my silverlines on the lupo? Albeit not stainless, the only drawback. "
"One of the best things about AP Coilovers is that they are actually designed and tested ON VEHICLE! They are however despite AP Being a German company Assembled in and Distributed from Germany.
There are only 4 coilover manufacturers who actually do this! (AP - KW - Billstein and H&R) The rest of them all just do Calculations and work out damping rates by Percentages ontop of the original."
Este ultimo comentário diz praticamente tudo...
Posso continuar, mas depois não iria haver espaço suficiente no fórum
