Re: A3 8p spb algarve
malta fiz scan hoje pela 1vez carro e ate me assustei parece um testamento será que me podem ajudar nisto?VCDS Version: Release 12.12.0
Data version: 20130910
Thursday,28,November,2013,19:45:34:62939
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 57 62 72 77
7D
VIN: WAUZZZ8P96A090316 Mileage: 103780km/64485miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 7364
Revision: 12345678 Serial number: AUX7Z0E9FNK04G
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6CD7223B4F7E2C7E58B-8039
1 Fault Found:
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 1 1 0 0 0
Address 03: ABS Brakes
Cannot be reached
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH17 0200
Revision: 253495 Serial number: 8P0820043H
VCID: 3169F34FA8DC81962BD-8064
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:39:03
Freeze Frame:
Voltage: 9.00 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H36 1201
Revision: 00H36000 Serial number: 00000002255269
Coding: 01884F019214100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408FA68B1376181ED43-8015
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.26
Time: 15:34:00
Freeze Frame:
ON
Voltage: 11.05 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.26
Time: 15:34:00
Freeze Frame:
ON
Voltage: 11.05 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H12 3760
Revision: 91H12376 Serial number: 00362004ZCP1
Coding: 0073622
VCID: 428BAC831D7A0A0EC27-8017
Subsystem 1 - Serial number: 6332DRB402384821B
Subsystem 2 - Serial number: 6342DRB40253C814J
Subsystem 3 - Serial number: 63528RB400B40D89P
Subsystem 4 - Serial number: 63628RB400B5B22BN
Subsystem 5 - Serial number: 63729RB400BB784E
Subsystem 6 - Serial number: 63829RB400BB78F0-
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:39:39
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000012
VCID: 76E300530132E6AEBEF-8023
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 R HW: 8P0 920 930 R
Component: KOMBIINSTR. VDO H80 0420
Revision: D06 Serial number: 2249ED06042940
Coding: 0004143
Shop #: WSC 00011 888 96745
VCID: 4189A38F187C1116DBD-8014
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:38:47
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A158763
Coding: 3D3F0BDA072102
VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
00467 - TV Tuner (R78)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 154
Mileage: 95630 km
Time Indication: 0
Date: 2013.04.16
Time: 12:53:07
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0E9FNK04G
Shop #: WSC 00000 000 00000
No fault code found.
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H80 0660
Revision: 11S Serial number: AUZBZ7L3378492
Coding: 0205712
VCID: 3561C75F5CB4ADB6775-8060
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:40:47
Freeze Frame:
Voltage: 11.10 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 194
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:36:22
Freeze Frame:
Voltage: 10.80 V
Mileage: 103780 km
Count: 2811
Clock: 00:30
Freeze Frame:
Fault Priority: 5
Fault Frequency: 23
Reset counter: 154
Mileage: 102497 km
Time Indication: 0
Date: 2013.09.21
Time: 01:12:57
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000144
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
Freeze Frame:
Mileage: 3760 km
Temperature: 17.0°C
Voltage: 6.40 V
Voltage: 7.20 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D088505488F016300
VCID: 3E73D87369826EEEA6F-806B
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674526207543
VCID: F1E9B34FE85C4196EBD-80A4
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:42:46
Freeze Frame:
Temperature: 20.0°C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:40:20
Freeze Frame:
Temperature: 20.0°C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000144
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205712
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:40:47
Freeze Frame:
Voltage: 11.10 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 194
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:36:22
Freeze Frame:
Voltage: 10.80 V
Mileage: 103780 km
Count: 2811
Clock: 00:30
Freeze Frame:
Fault Priority: 5
Fault Frequency: 23
Reset counter: 154
Mileage: 102497 km
Time Indication: 0
Date: 2013.09.21
Time: 01:12:57
Address 57: TV Tuner
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0060
Coding: 0000144
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005583834
Coding: 0010302
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 103768 km
Time Indication: 0
Date: 2013.11.28
Time: 01:39:31
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E5760F5-8078
tive pesquisando e acho que tem a ver com bateria do carro.ontem quando fui buscar carro pintor ele disse me que carro tinha ido abaixo uma vez e nao pegou logo coisa que a mim nunca aconteceu ah mais de 1ano que tenho e sempre pegou ah primeira,entretanto quando tava de abalada do pintor quando for dar ah chave nem sinal dava fiquei parvo ele lá me ligou os fios e la comecou trabalhar e desde ontem nunca mais deu sinal tem pegado bem,sera que estes erros é disso?
