A5 2.7TDI - Sline
Tópico em 'A5 / S5 / RS5' iniciado por semoG, 27 Dez 2012.
  1. semoG
    semoG
    Desde:
    1 Out 2008
    1 921
    Gostos Recebidos:
    72
    Viva meus caros, é com enorme prazer que inicio aqui o meu novo projecto, o meu sonho:
    CARACTERISTICAS TÉCNICAS:
    Marca:
    - Audi
    Modelo:
    - A5 8T
    Mês/Ano:
    - 08/2009
    Motor e Transmissão:
    - 2.7 V6 TDi / 6MT
    Jantes/Pneus:
    - A5 Sline OEM 18"
    Exterior:
    - Pintura: Black
    - Sline
    - Vidros escuros OEM
    - AFS Headlights
    Interior:
    - Sline
    - Tecto Preto
    - Estofos/Bancos Sline (Full leather) c/ regulação lombar electrica, resto manual.
    - Cortina Automática
    - Espelho Anti-Encadeamento
    Multimédia:
    - MMI 3G
    - HDD
    - DVD
    - 6 CD Changer
    - Aux - IN
    Option Codes:
    E4J = "S-line"
    7D1 = CD changer and DVD player
    4UE = Air bag for driver and front seat passenger
    6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
    5SL = Left exterior mirror: aspherical
    6TS = Right exterior mirror: aspherical, large viewing field
    1KW = Disc brakes, rear
    J0Z = Battery 520 A (110 Ah)
    1LA = Disc brakes, front
    1AT = Electronic stabilization program (ESP)
    1BE = Sports suspension/shock absorption
    3FA = Without roof insert (standard roof)
    5TG = Decorative aluminum inserts, dulling
    7X4 = Park distance control, front and rear
    F0A = No special purpose vehicle, standard equipment
    8GU = Alternator 140 A
    0G1 = Gearshift lever
    0YF = Weight range 6 installation control only, no requirement forecast
    0JG = Weight category front axle weight range 7
    TA1 = 6-cylinder diesel engine 2.7 L unit 059.F
    3NZ = Rear seat bench unsplit, backrest split folding
    8BP = Bi-functional headlight with gas discharge lamp
    U2A = Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
    X0A = National sales program Germany
    1N3 = Speed-related variable steering assist (Servotronic)
    1XW = Leather trimmed multi-function sports steering wheel
    8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
    9Q4 = Multi-function display/on-board computerwith check control
    8Z5 = Not hot country
    D4V = 6-cyl. turbo dies. eng. 2.7 L/140 kW 24VV6 TDI, common rail base engine is TA1/TH1
    7T6 = Navigation system (MID)
    C3A = Alloy wheels 8.5J x 18
    7K6 = Flat tire indicator
    4X3 = Side air bag front with curtain air bag
    2K7 = Reinforced bumpers
    3L3 = Manual height adjustment for front seats
    VW1 = Side windows tinted green, from B-pillarto rear window gray tinted safety glass
    3Y2 = Electrically operated roll-up sun screenfor rear window
    4K4 = Radio remote controlled central locking
    5D7 = Carrier frequency 868 MHz without panic button
    1SA = Without additional front underbody guard
    7MG = Emission standard EU5
    Q1D = Sports front seats
    4GF = Windshield in heat-insulating glass
    Modificações Feitas (Vag-Com):
    - Efficient Programa on FIS
    [​IMG]
    - video - in - motion
    - Audi Drive Selection (modo dynamic para o motor e direcção)
    [​IMG]
    - Hill Hold Assist "lite"
    - Espelho desce para fazer marcha-atrás
    - Hidden MMI Menu
    - Ripping CD's to jukebox
    - Nivel de Bateria no MMI
    - Nível do Oleo (ja vinha penso eu)
    - Lap timer
    (vou colocando mais ao longo do tempo e se me for lembrando de tudo.
    spyphoto :
    [​IMG]
    spyvideo :
    4 pessoas gostam disto.
  2. semoG
    semoG
    Desde:
    1 Out 2008
    1 921
    Gostos Recebidos:
    72
    Proximas mods :
    - Grelha RS5 - Preta com o aro e argolas cromados :)
  3. kevinzaooo
    kevinzaooo
    Desde:
    6 Set 2011
    1 606
    Gostos Recebidos:
    475
    não consegues fazer edit do teu primeiro post?
    btw, grande maquinão que ai tens!
    adoro!
  4. Keps
    Keps
    Desde:
    20 Jul 2011
    453
    Gostos Recebidos:
    115
    Tiveste 9 horas para fazer o 2º post :p
    Podes sempre editar o teu 1º post para adicionar fotos...
  5. BlueA4
    BlueA4
    Desde:
    3 Fev 2011
    5 122
    Gostos Recebidos:
    2 250
    Bela maquina ;)
    Adoro esse carro,Boa sorte com ele ;)
  6. semoG
    semoG
    Desde:
    1 Out 2008
    1 921
    Gostos Recebidos:
    72
    Não me chegou o mail da confirmação do Projecto, não sei bem porque, dai nao ter feito logo o segundo post.
    Mas sim eu posso editar o primeiro, já enviei uma mensagem , espero que a pessoa certa.
    Obrigado a todos pelos comentários :)
  7. ruicor
    ruicor
    Desde:
    28 Mar 2007
    2 245
    Gostos Recebidos:
    1 451
    Parabéns Semog, realmente é uma máquina de sonho.
    Abraço da madeira.
  8. audi a6 30 TDI
    audi a6 30 TDI
    Desde:
    6 Fev 2011
    6 121
    Gostos Recebidos:
    1 095
    Muito boa máquina e bem equipada!
    Boa sorte com ela e toca a enchê-la de mimos!
    Depois explica-me por pm aquilo que falaste no projeto do wolf sobre quem não tem drive select ;)
  9. tecno321
    tecno321
    Desde:
    23 Set 2009
    2 178
    Gostos Recebidos:
    367
    Parabéns pela tua nova viatura. Agora é gozá-lo.
  10. Santinhos
    Santinhos
    Desde:
    23 Set 2006
    3 485
    Gostos Recebidos:
    3 456
    O carro é brutal so é pena nao ser o 3.0 :D :D
  11. semoG
    semoG
    Desde:
    1 Out 2008
    1 921
    Gostos Recebidos:
    72
    Obrigado. Andava a namorar um A5 a algum tempo, e embora nao estejamos em epoca de se arriscar muito, a ver vamos como me dou com este sonho :)
    Posso explicar até detalhadamente se quiseres, mas penso que se vê na foto em cima o que realmente se trata, basicamente quem tem audi drive select tem uma suspensão diferente e por norma também um diferencial diferente (Sport Diferencial), mas para alem disto existem mapas na ECU para o motor e a direcção.
    Ora estes mapas consegues aceder após umas alterações com o VAG, deu algum trabalho porque nao funcionou a primeira mas la consegui.
    Conclusão, tenho uma especie de modo Sport no carro com um toque no MMI . (claro, apenas com o carro parado e que se pode mudar).
    Quem nao tem MMI pode fazer na mesma, mas fica com o modo bloqueado e so o pode mudar com VAGCOM.
    Obrigado, para mim ter um V6 foi passar para um outro mundo completamente diferente.
    Foi opção, acredites ou não. Mas obrigado :)
  12. Santinhos
    Santinhos
    Desde:
    23 Set 2006
    3 485
    Gostos Recebidos:
    3 456
    opa estou so a meter-me ctg... nao ta ca mais ninguem para chatear :D :D deve estar tudo de ferias :D
    Boa sorte para a maquina :) agora siga nas mod's:
    - repro
    - jantes 20"
    - turbo 24
    - Ic xxl :D :D
  13. Brazuko
    Brazuko
    Desde:
    5 Jan 2011
    2 058
    Gostos Recebidos:
    817
    Linda maquina.. Parabéns!!!
    Realmente, umas 20" nisto ficava no ponto!! ;)
    Boa sorte.
  14. audi a6 30 TDI
    audi a6 30 TDI
    Desde:
    6 Fev 2011
    6 121
    Gostos Recebidos:
    1 095
    E isso será que funciona no meu A6 que tem um mmi antigo que o do teu?
    Estou tentado a fazer uma coisa igual :)
  15. Racing_Green
    Racing_Green
    Desde:
    15 Ago 2008
    975
    Gostos Recebidos:
    112
    Muitos parabéns pela belíssima máquina!!
    Além dos Porsche, é um dos meus maiores carros de sonho, atingíveis, claro!!
    Agora, usufrui e que te dê muitas alegrias ;)
Partilhar esta página
