VAGCOM: o primeiro diagnóstico...
Ora VAGCOM na mão, portátil noutra, bora lá fazer o diagnóstico ao "velhote"...
Após algumas horas perdidas a instalar o VAG, lá consegui ligá-lo ao carro... eis o resultado do primeiro diagnóstico:
Tuesday,28,August,2012,22:05:03:10074
VCDS Version: Release 10.6.5 (x64)
Data version: 20110930
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 264650km/164445miles
Address 01: Engine
Part No: 8D0 907 557
Component: 1,8l R4/5VT MOTR HS D05
Coding: 04001
Shop #: WSC 00000
8 Faults Found
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
00670 - Throttle Position Sensor (G127)
27-10 - Implausible Signal - Intermittent
16705 - Engine Speed Sensor (G28 ): Implausible Signal
P0321 - 35-10 - - - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Shop #: BB 37402
VCID: 2F69178FC786
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 H
Component: A4-KLIMAVOLLAUTOMAT_D65
Coding: 00040
Shop #: WSC 00011
VCID: 2545F5A7957A
Address 15: Airbags Labels:
VCID: 55A58567859A
Note: Excessive Comm Errors
Address 17: Instruments Labels: 8D0-919-0xx-17.lbl
Part No: 8D0 919 033 P
Component: B5-KOMBIINSTRUMENT__D11
Coding: 00142
Shop #: WSC 54321
VCID: 356525E725DA
Address 25: Immobilizer Labels: None
Part No: 4A0 953 234
Component: IMMO AUZ9Z0T3734289 D77
Coding: 00000
Shop #: WSC 00000
VCID: DFC9274F77A6
Ora, há aqui erros que não me surpreendem... a bateria fraca, o imobilizador (já me aconteceu ele ser accionado não sei porquê, mas pronto ficou registado), a MAF (penso que limpando talvez vá ao sítio), o sensor do líquido de refrigeração também já esperava...
Agora isto:
Refere-se a quê? :S
Ah e de referir que guardei esta lista e apaguei os erros...
Fiz mais uns kms e novo diagnóstico e agora não me aparece nada...:roll:
Fiz asneira??
Address 01: Engine
Coding: 04001
Shop #: WSC 00000
8 Faults Found
Readiness: N/A
Shop #: BB 37402
VCID: 2F69178FC786
Coding: 00040
Shop #: WSC 00011
VCID: 2545F5A7957A
VCID: 55A58567859A
Coding: 00142
Shop #: WSC 54321
VCID: 356525E725DA
Coding: 00000
Shop #: WSC 00000
VCID: DFC9274F77A6
Agora isto:
Refere-se a quê? :S
Fiz asneira??
