1) Eu já liguei ao VAG e deu estes gatafunhos
VIN: Wxxxxx1x11x111111 License Plate:
Mileage: 285820km-177600mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 200)
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: Wxxxxx1x11x111111 Mileage: 285820km/177600miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC 0000SG 1572
Coding: 00002
Shop #: WSC 63351
VCID: 72EDAA8A3ED84B8E9D9-4A9C
WAUZZZ8E93A237695 AUZ6Z0B0288466
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
VCID: E5C741D67F162C3688B-5000
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 264586DAC290672EC11-5072
2 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
VCID: 34616C92044C05BE4F5-4A9C
3 Faults Found:
79-10 - Please Check Fault Codes - Intermittent
01312 - Powertrain Data Bus
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 3665569A423017AE711-5072
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00011
Shop #: WSC 63351
VCID: 3665569A123017AE711-4A3A
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 900 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00100
Shop #: WSC 00005
VCID: 2C5174F2DC7C5D7E175-5072
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 AT
Component: Komfortgerát T23 1210
Coding: 06752
Shop #: WSC 00005
VCID: 83037F4E9162F20606F-4A3A
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
5 Faults Found:
00955 - Key 1
35-10 - - - Intermittent
01332 - Door Control Module; Passenger Side (J387)
53-10 - Supply Voltage Too Low - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01561 - Rear Left Door
61-00 - Won't De-Safe
01562 - Rear Right Door
61-10 - Won't De-Safe - Intermittent
2) Baril, menos um problema :roll:
3) Ontem em Sintra por exemplo, estava um calor da Sibéria e estava a marcar 17,5º....nem sol estava! No cabo da roca acho que lasquei um dente de tanto bater a dentuça e ele marcava 16º. Já tenho andado a reparar que aquele carro é muito modesto
mas se calhar é mesmo assim
4) Quando falo pisar a fundo a 130, falo em ir às 2000 e qualquer coisa rotações e pisar o pedal a fundo! O carro não vai em esforço nem nada, mas ele começa a evoluir, a subir rotação mas parece que começa a tremer que eu inté tenho medo! Se for acelerando mais levezinho não se nota.
Realmente já gastei uns trocos valentes lá, mas ainda falta o kit de braços de suspensão, e creio que seja daí, mas queria saber se alguém já tinha tido uma situação destas.
De motor não deve ser, porque já experimentei puxar por ele em velocidades mais baixas e até fico maricas dos olhos...
Bem, vamos ver depois de lhe mudar os braços se continuam nesta doideira.
Obrigado Vitor
