[A4 B7] Audi A4 B7 2.0 TDI/AVANT RS4
Tópico em 'A4 / S4 / RS4' iniciado por Mauro Oliveira, 6 Out 2019.
  1. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Okay...sendo que levará cablagem original a ligar no módulo...para que cada luz acenda com a respectiva porta aberta...assim sendo é compatível certo? Não será necessário trocar o módulo é isso?
  2. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    ....após muita pesquisa encontrei informação pertinente relativo aos módulos de conforto dos/das B7:
    partilhado aqui: https://www.audipt.com/threads/modulo-confort.114156/
    e aqui:
    " Tree next driver comfort for the body B7:
    The list of modules for B7:
    8E0 959 433 BG - 433MHz, the crank (or electrician).
    8E0 959 433 BH - 433 MHz, power windows in the rear.
    8E0 959 433 BJ - 433MHz, leg space lighting package, rear power windows
    8E0 959 433 AB
    8E0 959 433 BL
    8E0 959 433 BM - factory alarm, 433MHz, leg space lighting package, rear power windows
    8E0 959 433 BN - factory alarm, 433MHz, crank
    8E0 959 433 BP - 433 MHz, power windows at the back (or crank).
    8E0 959 433 BQ - 433MHz, power windows in the rear.
    8E0 959 433 BR - 433MHz, leg space lighting package, rear power windows
    8E0 959 433 BS - 433MHz, leg space lighting package, rear power windows (or crank).
    8E0 959 433 BT - factory alarm, 315MHz, leg space lighting package, rear power windows
    8E0 959 433 CA - faryczny alarm, 433MHz, leg space lighting package, power windows in the rear.
    8E0 959 433 CB - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
    8E0 959 433 CC - 433 MHz, power windows at the back (or crank).
    8E0 959 433 CD
    8E0 959 433 CE - 433 MHz, leg space lighting package, rear power windows
    8E0 959 433 CF
    8E0 959 433 CG - factory alarm, 315MHz, leg space lighting package, rear power windows
    8E0 959 433 CH - factory alarm, 433MHz, rear power windows
    8E0 959 433 CJ - factory alarm, 433MHz, leg space lighting package, electric rear windows (or crank).
    8E0 959 433 CK - 433MHz, crank
    8E0 959 433 CL
    8E0 959 433 CM
    8E0 959 433 CN - 433MHz, lighting package over the legs, crank
    8E0 959 433 CP
    8E0 959 433 CQ
    8E0 959 433 CR
    Encoding module comfort
    Select option CODING 07 (to activate the functions we add to each other the following values ??and their sum is written as a driver coding):
    1 - alarm activation (version for UK and Ireland)
    2 - confirmation of the activation / deactivation of the alarm signal by the corresponding diodes in the driver's door
    4 - Selective central locking (when opening the car with the remote control, a button will only open the driver's door, fuel filler flap and turn off the function of SAFE - the second press will open the other door locks and unlocks the bonnet and boot)
    8 - Alarm activation
    16 - Lock tailgate lock beyond 5km / h (the lock will unlock automatically when you release below 5km / h)
    32 - lock all the door locks after crossing the 10km / h (locks are opened only after removing the key from the ignition, or by manually opening the door by pressing the central locking in the driver's door panels)
    64 - Activate additional comfort module functions (the ability to open / close windows and sunroof with the door lock and remote control)
    128 - a vehicle with a left hand drive
    256 - activation-break sensors, rear side windows (only for the Avant body equipped with factory alarm)
    512 - Confirmation of successful closure of all locks with the remote control by a single blink turn signals
    1024 - further confirmation of the alarm activation by a single beep from the alarm siren
    2048 - rules concerning the power window lifts (after turning off the ignition and removing the key from the ignition window winders will be fed for another 10 minutes or until you open the door)
    4096 - Additional features burglar When you open the car key will unlock only the driver's door, other doors and locks will be unlocked after the ignition. If the car has a factory alarm when you open the driver door key - the ignition must be switched on within 15 seconds (otherwise it will release an alarm).
    8192 - disable SAFE (only for USA and Canada - versions of cars designed for this market have only one engine in the castle, the other cars have two - one lock closes and the second activates the SAFE or the inability to unlock the car from the inside - the switch in the upholstery driver's door - after closing the car remote control or key)
    16384 - Information for motors mounted shaft with double-layer glass
    Adaptation Module comfort
    Option Module comfort - ADAPTATION 10, channel 61:
    0 - no additional lighting over the feet, the rear door windows in electrical
    1 - without additional lighting over the foot, glass rear door cranks
    2 - additional lighting feet, rear door windows in electrical
    3 - additional lighting foot, glass rear door cranks
    Activation of the options of comfort - ADAPTATION 10, channel 62:
    1 - Comfortable remote window closing
    2 - Comfortable remote control to open windows
    4 - comfort closing windows key
    8 - Comfortable open windows key
    16 - Comfortable remote closing of sunroof
    32 - Comfortable remote control opening sunroof
    64 - Comfortable closing sunroof key
    128 - Comfortable key opening sunroof
    The last two letters are revsion numbers for the part, From Vag-com the 8E0-959-433 modules are as follows;
    8E0-959-433-MIN.LBL,8E0-959-433-J ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-K ; MIN
    ;8E0-959-433-L ;
    8E0-959-433-MIN.LBL,8E0-959-433-N ; MIN
    ;8E0-959-433-Q ;
    ;8E0-959-433-R ;
    ;8E0-959-433-S ;
    8E0-959-433-MAX.LBL,8E0-959-433-T ; MAX
    ;8E0-959-433-AA ;
    ;8E0-959-433-AB ;
    8E0-959-433-MIN.LBL,8E0-959-433-AC ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-AD ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-AE ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-AF ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-AG ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-AH ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-AJ ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-AK ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-AL ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-AM ; MIN
    ;8E0-959-433-AN ;
    8E0-959-433-MAX.LBL,8E0-959-433-AP ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-AQ ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-AR ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-AS ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-AT ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-BA ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-BB ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-BC ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-BD ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-BG ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-BH ; MAX
    ;8E0-959-433-BJ ;
    ;8E0-959-433-BK ;
    ;8E0-959-433-BL ;
    8E0-959-433-MAX.LBL,8E0-959-433-BM ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-BN ; MIN
    8E0-959-433-MIN.LBL,8E0-959-433-BP ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-BQ ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-BR ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-BS ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-BT ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CA ; MAX
    ;8E0-959-433-CB ;
    8E0-959-433-MIN.LBL,8E0-959-433-CC ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-CD ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CE ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-CF ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-CG ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CH ; MAX
    8E0-959-433-MIN.LBL,8E0-959-433-CJ ; MIN
    8E0-959-433-MAX.LBL,8E0-959-433-CK ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CL ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CM ; MAX
    ;8E0-959-433-CN ;
    8E0-959-433-MAX.LBL,8E0-959-433-CP ; MAX
    8E0-959-433-MAX.LBL,8E0-959-433-CQ ; MAX
    Adding a MAX version usually would add more functionality but only replace it with a newer revision. As in BQ is max and BR max should be compatible.
    Black Drako gostou disto.
  3. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Encomenda a caminho...mais uma ponta...do véu...
  4. Black Drako
    Black Drako
    Desde:
    27 Nov 2011
    3 591
    Gostos Recebidos:
    1 983
    Travao de mao?
    Mauro Oliveira gostou disto.
  5. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Yap
  6. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Para muito breve...e para finalizar as mods OEM...uma grande surpresa....fiquem atentos ao projecto!
  7. jimy
    jimy
    Desde:
    10 Mar 2010
    8 336
    Gostos Recebidos:
    6 317
    Vendi carradas disso...
  8. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Oi jimy...imagino...ainda vendes...
  9. Black Drako
    Black Drako
    Desde:
    27 Nov 2011
    3 591
    Gostos Recebidos:
    1 983
    Estao a falar do que?
  10. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Curioso:D:D:D
  11. Black Drako
    Black Drako
    Desde:
    27 Nov 2011
    3 591
    Gostos Recebidos:
    1 983
    Claro! :D
  12. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Penso que o @jimy se estava a referir a peças de "decor" para as B6 B7, tais como: manetes das velocidades, apoios de braço, punho travão de mão (o meu caso é do RS4), etc, etc...mas ele saberá dizer melhor do que eu ;)
  13. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Sobre a grande novidade, em breve darei notícias...e depois coloco aqui algumas fotos para "adoçar" a boca e partilhar com todos :D;)
    PedroABLima gostou disto.
  14. Mauro Oliveira
    Mauro Oliveira
    Desde:
    10 Jan 2019
    72
    Gostos Recebidos:
    34
    Aqui está mais uma novidade...punho do travão de mão do RS4...acabadinho de chegar :)
    Quando estiver no sítio aviso;)
    Fiquem descansados:D
    Black Drako e rro gostam disto.
  15. rro
    rro
    Desde:
    6 Abr 2019
    262
    Gostos Recebidos:
    43
    Muito fixe.
    Gostava de substituir a manete (moca) da caixa de velocidades do meu A5 de 2010 (caixa automática), mas parece que não se vende em separado....
Partilhar esta página
