Audi [B6] Luz do ESP ligado
Bem, saio do trabalho, ligo a carrinha aparece desta vez a luz de ESP (já não apareceu a de ABS), ando uns metros apaga-se a de ESP e tenho tudo a funcionar bem como normalmente... :S
Chego a casa, passo o VAG e deu os seguintes erros:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 218770km/135937miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JL
Component: 1,9l R4 EDC G000SG 1519
Coding: 00002
Shop #: WSC 63351
VCID: 6AD0DE2C3C03
WAUZZZ8E73A040816 AUZ6Z0B0140924
1 Fault Found:
18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
P1699 - 35-00 - -
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04155
Shop #: WSC 00011
VCID: E5CA2D10551D
2 Faults Found:
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 35-10 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
VCID: 2F660F38C761
4 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
29-00 - Short to Ground
00466 - Control Module for Steering Column Electronics (J527)
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 63351
VCID: 346C00542E47
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010702
Shop #: WSC 63351 000 00000
VCID: F4EC4054EEC7
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 M
Component: Lenksáulenmodul 0209
Coding: 02242
Shop #: WSC 63351
VCID: 3D7A25701D0D
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 J
Component: KOMBI+WEGFAHRS. RB4 D28
Coding: 02301
Shop #: WSC 01317
VCID: 2E58123CC06B
Part No: 40816
Component: AUZ6Z0B0140924
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Address 37: Navigation Labels: Redir Fail!
Part No: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0102
VCID: 234EF3089BA9
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AD
Component: Komfortgerát T85 0316
Coding: 07024
Shop #: WSC 64443
VCID: 73EEC3486BC9
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
4 Faults Found:
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00060
Shop #: WSC 63351
VCID: 040C90943E67
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 40215
VCID: 234EF3089BA9
Apaguei os erros, fui dar uma volta, desliguei voltei a ligar e não voltou a aparecer.... Alguém sabe do que se tratou/trata???
Obrigado,
Houve ai um stress com o SMLS...
Deste encosto de bateria a alguém ou vice versa?
Não nada disso... Ainda ontem usei a carrinha e nada de erros....foi assim do nada, hoje de manhã...a única alteração que efectuei foi à um mês, que coloquei minimos em led e novas lampadas de xénon... Mas para isso tinha dado erro na altura...
O meu receio é que isto volte a acontecer :o
E voltou a acontecer esta semana!
De manhã vou para arrancar lá fica acesa luz de ABS e ESP e todos os comandos eléctricos off (excepto rádio)!
Quando chego ao local de trabalho, desligo e volto a ligar e continuavam ligadas as luzes de erro e continuava sem vidros elétricos, piscas, ...!
No final do dia, ligo a carrinha e já só estava ligada a do ESP, já era possível ligar todos os acessórios eléctrónicos que antes não dava e passado uns metros lá se apaga a luz de ESp... Aqui há gato... Não sei é onde será :S
Actualização da situação:
Hoje vou à tarde para trabalhar e ao ligar a carrinha fica novamente ligada a luz de ESP e ABS!
Ao final do dia, eis que desta vez ao ligar a carrinha as luzes se mantêm ligadas. Não ligou apenas a ESP e desligou-se assim que comecei a andar como das outras vezes.
O que muda quando a luz de abs e esp ligam:
Não dá máximos nem piscas, cruise control tbm não funciona, não tenho buzina, portas não fecham automaticamente, sensores de estacionamento não funcionam, luz plafonier fica ligada durante uns segundos mesmo após motor ligado e em andamento e tbm não funcionam as escovas de limpeza do parabrisas.
As luzes funcionam, no entanto as de nevoeiro dá no botão indicação de ligadas mas não funcionam, rádio funciona (excepto comandos no volante), ar condicionado funciona, 4 piscas funciona, aquecimento dos bancos funciona, desembaciador funciona!
Outra cena que noto diferente é que quando tranco a carrinha com a chave ela após fechar manda passado 2seg um estalo na porta do condutor parece que volta a fechar mas só esta porta…
E ao tentar aceder por módulos, não me permite aceder a determinados módulos como por exemplo no modulo 09 cent. Elect.
Após passar o vag:
69 75 76 77
Mileage: 220520km/137024miles
Coding: 00002
Shop #: WSC 63351
VCID: 6AD0DE2C3C03
1 Fault Found:
P1699 - 35-10 - - - Intermittent
Coding: 04155
Shop #: WSC 00011
VCID: E5CA2D10551D
2 Faults Found:
P1628 - 35-00 - -
Coding: 00000
Shop #: WSC 63351
VCID: 2F660F38C761
4 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
29-10 - Short to Ground - Intermittent
49-00 - No Communications
Coding: 0010702
VCID: F4EC4054EEC7
Coding: 02301
Shop #: WSC 01317
VCID: 2E58123CC06B
Part No: 40816
1 Fault Found:
VCID: 234EF3089BA9
Coding: 00060
Shop #: WSC 63351
VCID: 040C90943E67
Coding: 00017
Shop #: WSC 40215
VCID: 234EF3089BA9
Desta vez tento apagar os erros e não dá, eles voltam a aparecer, não sei o que faça :'(
O teu problema é em tudo semelhante a um cliente que tive há umas semanas atrás.
A avaria foi o smls que berrou. Solução: trocamos por outro e voilá, ficou nice.
Ora bem, aproveitando este tópico...
No domingo passado, ia eu descansadinho da vida a uns meros 70/80km\h e a luz do ESP acende, carrego no botão para desligar e nada. Encosto, paro a B6 e volto a ligar, tudo normal. Depois disso fui a Fátima e andei toda a semana e nunca mais voltou a dar um ar da sua graça, até hoje de manha que voltou a acender, verifiquei as luzes de travão e acende tudo. O que é certo é que eu paro a carrinha e volto a liga-la e a luz nunca mais acende.
Das duas uma, ou é o tal Brake switch ou é a B6 que n gosta que ande devagar!!!!
Pode ser mais uma coisa..... Saudades de ir a Fátima !!!! LOL
Oh Jusak, não tem piada, esta treta anda a dar-me cabo da mona.
Eu sou daqueles gajos que não gosta de luzinhas no painel!!!
E ainda por cima a oportunidade de ir ao mecânico agora é só na sexta. Apouco voltou a acender, parei e voltei a ligar e apagou....
Acredito que sim, mas n resisti a fazer a piada com a nossa senhora. Boa sorte para a resolução do problema !!
