Log da carrinha LOOOOOOL
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 33278
5 Faults Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-00 - -
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 01523
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 933
Component: B5-KOMBIINSTR. VDO D13
Coding: 00064
Shop #: WSC 10001
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15179
Shop #: WSC 63351
2 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
1 Fault Found:
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
Address 56 -------------------------------------------------------
Controller: 8D0 035 192 G
Component: Radio BNO 0001
Coding: 00117
Shop #: WSC 63351
End -------------------------------------------------------
