Be certain you have stowed all carry on items under a seat, or in an overhead bin. Heavier items should be placed under a seat. Use caution if you open the overhead bin, and please close them securely, as items may shift in flight.
If you are seated in an exit seat, you must be able to see the exit, hear instructions, open the exit, and verbally direct others to the exit. You must be able to do this without blocking the exit, causing harm to yourself, or being distracted by other attentions. Children under 15 may not sit in an exit seat. If you are seated in an exit seat, and do not meet these requirements, or do not wish to sit there, please notify a flight attendant at this time.
Cellular phones may only be used while the aircraft is at the gate and the boarding door is open. All cellular phones must be turned off and stowed when the boarding door is closed. Certain electronic devices may not be used onboard at any time. Approved electronic devices, listed in the in-flight section of "Southern Way" magazine, may be used when advised by crewmembers.
Please discontinue the use of all electronic devices at this time, and be certain to properly stow all tray tables, footrests, and in-seat video units where applicable. Smoking is not allowed on any Delta aircraft, and Federal law prohibits tampering with, disabling, or destroying a lavatory smoke detector. Lighted signs are visible throughout the cabin, and Federal regulations require you to comply with all signs and crewmember instructions.
To fasten your seatbelt, place the metal tip into the buckle, and tighten the straps so that it fits low and tight across your hips. To release, lift the top of the buckle. During the flight, the fasten seatbelt sign may be turned off, however, for your safety, we require that you keep your seatbelt fastened at all times while seated.
If cabin pressure should change, panels above your seat will open revealing oxygen masks; reach up and pull a mask towards you. Place it over your nose and mouth, and secure with the elastic band, that can be adjusted to ensure a snug fit. The plastic bag will not fully inflate, although oxygen is flowing. Secure your own mask first before helping others.
Exits on the Boeing 777 are eight doors; four on each side of the aircraft. Each door is equipped with a detachable slide that can be used as a raft. If there is a loss of electrical power, emergency track lighting near the floor will illuminate. White lights lead to red lights and exit signs, which indicate the exit. Please take a moment to locate your nearest two exits, keeping in mind that the closest exits may be behind you.
Life vests are located beneath, or between your seats. Remove the vest from the pouch by pulling on the tab. Place the vest over your head, and fasten the straps to the front of the vest. Adjust the straps loosely around your waist. As you leave the aircraft, inflate the vest by pulling down on the red tabs, or manually inflate by blowing into the tubes on either side. A light can be activated in the water by pulling down on the tab in front. Do not inflate your life vest inside the aircraft.
We recommend reviewing all of the safety information, which can be found in the passenger safety information card, located in your seat pocket. To prepare for takeoff, please store your tray table, bring your seat upright, and discontinue the use of all electronic devices. At this time, flight attendants will be picking up any remaining beverage items.
