Venho aqui ao off topic fazer uma pergunta, se calhar parva, mas caso me respondam, deixo de viver na ignorância
"ali ao lado" falasse em cabos VAG 409. o Meu cabo diz VAG912, qual a diferença?!
In Ross Tech
Release 409 posted 03 October 2004
Clear All DTCs functions
Support for Transport Mode ON/OFF for Golf-5 Platform and Audi A8(4E) chassis cars.
Fixed incompatibility with older Sharan (7M platform) 09 modules.
CODES file enhanced with texts for 2005 models.
Ability to decode Readiness bits for modern TDI engines
Support for selectable window sizes for higher-resolution laptops.
New Label File redirection methods
New Version 1.7 VAG-Scope
New Version 1.3E of TDI-Graph
SAVE CODES button on Fault Codes Screen.
This version is no longer supported. Customers using "dongle" type interfaces should update to the current version of VCDS. Customers using obsolete "dumb" or third-party interfaces should update to VCDS-Lite.
Release 908 posted 30 August 2009
Supports Measuring Values, Output Tests, and Adaptations on control modules using the new UDS/ODX/ASAM protocol.
Adds new UDS addresses and updated ODX data for 2010 models.
Includes support for TP1.6 protocol which is required for the 6J Ibiza and speeds up access on many modules in other models.
The Select Control Module screen now shows "Installed Modules" rather than "Common Modules" if the car being worked on is new enough to have a proper CAN Gateway.
Modified SRI Screen to show more info and force user to select a job before proceeding.
Adds drop-box function selection in Basic Settings and Adaptation.
Reads Mileage stored in many EDC16 ECUs.
New CODES file, now with over 13,000 fault code and measuring value texts.
New USB drivers for enhanced PC compatibility and stability.
New firmware for HEX interfaces required for compatibility with 6J Ibiza
Updated Label files; better documentation for new and existing models.
Too many other improvements to list here. For details see the Beta 812, 904, and 907 pages.
This version is no longer supported. Users should update to the current version.
http://www.ross-tech.com/vcds/revisions.html
Não existe na Ross Tech versão 912
