neljoe
Moderator
Re: A4 B5 Avant - Sport 115 - 2001 - Chrome on Black - ESPELHOS_PINTADOS@PÁG. 35
É bem.
AUDIMANÍACO disse:Tenho uns Koni Sport
É bem.
neljoe disse:Segundo o que me disse um gajo dos States que tem uma B5 Sport com Molas Eibach Pro... ficará assim:
AKA, "em linha atrás" e "1 dedo á frente".
Veremos...
8)
Paulo Geraldes disse:É como está a minha Black Bitch. A tua Sra. vai-te insultar todos os dias , a minha anda farta de dizer que a carrinha ta muito baixa agora, que bate em todo o lado LOL.
JMMS disse:Reparando bem, nessas fotos a traseira está mais baixa :|
rmatos disse:pois...também achei um pouco esquesito...acho que deveria ficar toda por igual :roll: :roll:
edit: deve estar com o travão de mão puxado :roll:
Paulo Geraldes disse:Tu é que andas com o travão puxado, e ainda por cima de portão traseiro aberto. Cuidado com os larapios lol.
"B5 Spring Heights, OEM Non-Sport, Sport, and Aftermarket
A popular suspension modification is replacing the stock springs and shocks. Sometimes this is done to get better handling performance, sometimes just to lower the vehicle, and sometimes to do both. But often it's unclear what the data and specifications in the ads really mean.
The B5 came with a standard suspension that produced a ground clearance of 4.3 inches. An optional sport suspension was available with shocks and springs designed for better handling at the expense of a softer ride. The sport suspension lowered the vehicle by .75 inches (actually 20mm), giving it a ground clearance of about 3.5 inches.
Popular aftermarket springs lower the vehicle even more than the sport suspension. However, the lowering numbers listed in the ads for them are almost always based on the stock non-sport height. Here's the data for the commonly used springs:
H&R Sport Springs lower the car 1.25" in the front and 1" in the rear from the stock non-sport height or .5" in the front and .25" in the rear from the stock sport height.
H&R Race Springs lower the car 1.9" in the front and 1.5" in the rear from the stock non-sport height or 1.15" in the front and .75" in the rear from the stock sport height.
Vogtland Sport Springs lower the car 1.5" from stock non-sport height and .75" from stock sport height.
Vogtland Club Spec Springs lower the car 1.4" from stock non-sport height and .65" from stock sport height.
Eibach Pro-Kit Springs lower the car 1.4" in the front and 1.3" in the rear from the stock non-sport height or .65" in the front and .55" in the rear from the stock sport height.
WARNING: These numbers apply only to quattro AWD B5s. Numbers for 2001.5 MY B5s may differ because of the redesigned spring perches. Check with the manufacturer or your vendor to confirm.
The problem with lowering the vehicle is that the resulting reduced ground clearance may result in increased damage to the vehicle undercarriage due to debris on the road. Only the stock non-sport suspension, for example, can be counted on to get the vehicle safely over a 2x4 laying on end. Another problem with a lower vehicle is a reduced approach angle which may cause the front of the vehicle to scrape on driveways, speed bumps, etc. (or the rear of the vehicle if going backwards). You'll also risk bottoming out sooner in deep snow. Before you lower the vehicle, think about how this will impact your driving and repairs.
If you want performance without significant lowering, you have two choices. You can install coilovers in place of the shock/spring combination. Many coilovers are height adjustable. You can also install a performance shock with your OEM springs, sport or non-sport."
rmatos disse:
tem mazé cuidado com as aguas de sabores lol
rmatos disse:
neljoe disse:Também reparei nisso... mas será do facto de ele também não ter os Amortecedores OEM?
Aqui têm uma com apenas Molas Eibach Pro (30mm) + Amortecedores OEM Sport:
A Eibach Sport anuncia 50mm á frente e 40mm atrás... Eibach Pro anuncia 30mm em toda á volta. Serão medidas OEM non-Sport ou Sport? Durante a próxima semana estarão montadas...
Paulo Geraldes disse:Ei lá!! Alto lá. O que é que tu sabes Rudolfo Bernardo?
neljoe disse:E a gordura na Picanha!
rmatos disse:aguardo ansiosamente por essa montagem 8)
muitas coisas
esse num vi...tava ao tlm com um cromito e dps fiquei sem saldo
neljoe disse:Não, ó "cromito"!
1º ficaste SEM BATERIA, 2º ficaste SEM SALDO.
