neljoe
Moderator
Re: Black Motion Project... RNS... Fotos...
Não te quero estragar a festa mas essa é a Lista de NÃO COMPATIVEIS... e tendo tu um "A" de um 3C (Passat) não deverá ser mesmo compativel.
Mas, como é um "A" a info que lá tem é que dará para fazer um "update" do teu "0020" para o Software_Version "0178" que vem na "K" e aí tornar o teu "A" compativel.
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
Pelo descrito, basta ires á Audi/Seat/Skoda ou VW e pedir a respectiva "actualização"... será?
Apdate:
Poderei estar livre de "perigo"!
"Gateway
The Gateway (aka. Diagnostic Interface for Databus OR CAN-Gateway) is responsible for passing Messages from one Control Module to another, older versions of the Gateways were not compatible and caused the Databus to stay active even with the Ignition turned OFF which resulted in excessive Battery Draw and failure. To identify if your Gateway is compatible, check the (Software) Part Number and the Software Version of the Control Module shown in the Identification provided by VCDS (for example in an Auto-Scan)."
Control Module Part Number Software Version Compatible Notes
1K0-907-530-A 0020 No Update available
1K0-907-530-B 0050/0070 No Update available
1K0-907-530-C 0080 No Update available
1K0-907-530-D 0100 No Update available
1K0-907-530-E 0110 No Update available
1K0-907-530-F 0120 No Update available
1K0-907-530-G 0130/0140 No Update available
1K0-907-530-H 0150 No Update available
1K0-907-530-J 0160 No Update available
1K0-907-530-K 0021 No Replacement only
1K0-907-530-K 0170 No Update available
1K0-907-530-K 0178 Yes -
1K0-907-530-P 0191/0192 No Replacement only
"All Modules which Part Number has not been listed in the Table above are considered to be compatible. Those Part Numbers & Software Versions listed with the Note "Update available" can be updated to 1K0-907-530-K @ 0178, this often saves Money/Work which a Replacement of the Module would cause. The Update is NOT available in the US, all Rest of World VW/Audi, Seat and Skoda Dealers should have access to it."
Sendo o Part Number do meu :
3C0 907 530 A
Poderei estar safo?
A ver... Vamos!...
