lampadas xenon originais.
Hmm, ok, Obrigado!! Na loja que referenciaram atrás, tem luminosidade 4300, 5000 ou 6000k, há grande diferença entre elas? As 6000k não aquecem demais o plástico?
nao, a diferenca entre elas e a temperatura de cor e os lumens.
pelo que tenho andado a ler a de 4300K tem mais lumens mas eu acho as de 5000K melhores, sao o branco puro sem qualquer reflexo azulado das 6000K...
It depends on what you meam by "sacrificing too much light output?"
For one person 300-500 Lumens might be low loss, while for others too much. Generally speaking (based on Philips datasheets) and avg. 4100-4300K bulb (85122) can produce 3100-3400 Lumens, while a 4800K (85122CM) goes down to 2800 Lumens and 5800K (85122WX - Ultinon) goes down to 2400 Lumens. I can assure you that there is a noticeable difference in the output between these bulbs.
If you plan to go at 5000K try an OEM solution (like 85122CM or Osram Cold Blue etc.). You WILL LOSE Lumens, but still you will keep the major quality characteristics of the OEM bulbs. If you chose ANY a/m bulb higher than 4300K you'll be having a blue tinted output (even with 5000K bulbs), plus all the minuses from the lower quality of the bulb (compared to any OEM one). This is based on my personal experience.
IMO it's not worth sacrificing Lumens for Looks !... My 85122+s (after 30-40 hours of operation) have lost their original (extreme) yellowish tint (on the road) and have become (IMO) true (and very intense) white (with a bit of bluish tint - according to the road and the items they "hit" each time). Definatelly they're "blue" compared to standard halogen headlights.
The choice is yours...
mas outra coisa, nesse site e como disse o madlima, as lampadas sao replicas philips, mas replicas parece.me de boa qualidade.
dai custarem 30€ cada uma e nao 50€ ....
E mete 5000K que é o melhor delas todas a nivel de cor e luz.
4300k só compensa nos paises de muita chuva e neve.
Pois, mas se as réplicas durarem 3 anos, valem a pena.. O meu problema com o meu xenon é com chuva, parece que a luz bate na agua e reflete, em AE não gosto muito, não sei se será por terem 8 anos.. :)
Bem achado este site! O ano passado tbm compre um par de Phillips (provavelmente replica, não faço ideia) de d1s 6000k, durante 3 meses tudo bem, depois uma deixou de dar, até fundir, queixei-me ao vendedor que enviou nova lâmpada; A que chegou entretanto tinha mais cor amarelada que a outra de 6000k (e até que a de origem), voltou a enviar outra que mantinha cor mais amarela... farto de gastar €€em portes la acabou por andar até rebentar com um balastro... Depois de comprado novo balastro (€€) voltei a meter a lâmpada de origem! Actualmente a única de 6000k que lá andava começou a piscar e de vez em quando vai mesmo a baixo... Quando tiver tempo meto lá a lâmpada antiga para ver se é da Lâmpada ou do balastro outra vez! Mas saiu-me caro na altura a brincadeira... De referir que o vendedor foi outro, espero depois pelo feed-back, se for bom também avanço para a compra de umas 5000k!
tive um caso de lampada a piscar e passado um tempo desligava.se mesmo, e o problema era da lampada.
eu tinha umas lampadas philips 5000K H7 e fiquei maravilhaod, luz super brilhante e 100% branco, gostei mesmo da luz .
agora estas D2S e que me estao a dar algumas "dores de cabeca" a nivel de temperaturas de cor so uso 5000K, nem mais nem menos.
A nivel estetico e a nivel funcional para mim sao perfeitas, dao um aspecto original.
Boas, não percebi o teu comment, as luzes que compraste foi no site falado mas com outro vendedor? Desculpa mas não percebi mesmo..
Em Setembro comprei um kit da Osram D2S para o meu 8L e estou satisfeitíssimo!
Comprei no Ebay alemão, em menos de 2 semanas tinha as lâmpadas em casa, com a caixa embalada e selada de marca. São umas OSRAM D2S 5000K Xenarc Cool Blue Intense 66240CBI.
OSRAM D2S 5000K Xenarc Cool Blue Intense 66240CBI Xenon Brenner Birne Lampe NEU 4008321588883 | eBay
Tens aí o link. Ficaram-me a 143€ já com os portes. Antes tinha umas Phillips 85122 de 4300k. Notei que a luz ficou mais branca, sem NENHUM tom azulado, e iluminam muito bem. Estou muito satisfeito e aconselho ;)
Eu por acaso comprei umas lampadas d1s Philips 6000ºk (75e par) na loja do xenon nao fiquei nada satisfeito. As primeiras que comprei uma vinha danificada (partida) mandei para traz e as segundas que recebi duraram +/- 6meses depois foram a vida começaram a dar cor avermelhada entrei em contacto com a loja e a resoluçao nao foi a melhor....
entrando mais sobre o tópico as lampadas da philips podem ser sempre copiadas mas tem sempre uma particularidade nas lampadas que ninguém as consegue copiar e é aí que as destingem das verdadeiras/copias se procurarem no google talvez consigam saber. =)
Do melhor que pode existir para fazer upgrade (OEM)
quem quiser perder um bocadinho de tempo..New Osram D2S Bulb Xenarc Cool Blue Intense
eu encontrei um tópico da Renault a falar sobre isso :p
