Boas people, ora bem como ainda estou a espera entretanto hoje voltei a ligar meu VAG-COM apesar de nao detetar o carro automaticamente como no 1.6 , selecionei os modulos manualmente e fiz um auto scan, alguns modulos nao consegue ler, dava erro mas aos que consegui deu o seguinte:
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 8D0 907 557
Component: 1,8l R4/5VT MOTR HS D05
Coding: 04001
Shop #: WSC 00001
6 Faults Found:
00544 - Maximum Boost Pressure Exceeded
35-00 - -
16505 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
26-10 - Output Open - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 H
Component: A4-KLIMAVOLLAUTOMAT_D65
Coding: 00043
Shop #: WSC 06317
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 033 F
Component: B5-KOMBIINSTRUMENT__D07
Coding: 00142
Shop #: WSC 00186
1 Fault Found:
00667 - Ambient Temperature Signal
30-10 - Open or Short to B+ - Intermittent
Address 25 -------------------------------------------------------
Controller: 4A0 953 234
Component: IMMO AUZ9Z0S9544500 D76
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01176 - Key
07-10 - Signal to Low - Intermittent
End -------------------------------------------------------
Mais entendidos uma ajuda por favor
Coding: 04001
Shop #: WSC 00001
6 Faults Found:
35-00 - -
Readiness: N/A
Coding: 0265108005
Shop #: BB 37402
Coding: 00043
Shop #: WSC 06317
Coding: 00142
Shop #: WSC 00186
1 Fault Found:
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
01176 - Key
